Продам Specialized Hardrock
sergijtrupp
З нами з:6.6.14 17:03
Повідомлення sergijtrupp » 9.6.14 15:08
Specialized Hardrock Sport Disc 29", XL (21)
пробіг практично нульовий, подарунок, не підійшов по розміру(зросту). Ціна 7000грн.
FRAMESpecialized A1 Premium Aluminum, 29er Geometry, ORE downtube, externally relieved headtube, forged dropouts, reinforced disc mount, replaceable alloy derailleur hanger
SWAT
REAR SHOCK
FORKSR Suntour SF13-XCT-MLO 29", coil/MCU spring, 1-1/8" steel steerer, mechanical lockout w/ preload adj., 28mm stanchions, post-mount disc, 80mm travel
HEADSET1-1/8" threadless, loose ball
STEMAlloy, 4-bolt clamp, 10-degree rise, 25.4mm
HANDLEBARSSpecialized flat bar, alloy, 640mm/660mm wide, 8-degree backsweep, 4-degree upsweep, 25.4mm
GRIPSSpecialized Body Geometry XCT, Kraton w/ gel, 132mm
FRONT BRAKETektro HD-M330, hydraulic disc, dual piston, Light Wave style rotor, 160mm rotor
REAR BRAKETektro HD-M330, hydraulic disc, dual piston, Light Wave style rotor, 160mm rotor
BRAKE LEVERSTektro, hydraulic lever
FRONT DERAILLEURShimano Acera 9-speed, 34.9mm clamp, low-mount, top-swing, dual-pull
REAR DERAILLEURShimano Alivio, 9-speed, SGS Cage
SHIFT LEVERSShimano Altus, 9-speed Rapidfire Plus, SL type w/ optical display
CASSETTESunrace, 9-speed, 11-34
CHAINKMC X9
CRANKSETSR Suntour XCR, 9-speed, square taper spindle
CHAINRINGS44/32/22, steel
BOTTOM BRACKETSquare taper, cartridge bearings, 68mm shell
PEDALSComposite platform, w/ reflectors, 9/16"
RIMSHR Disc 29", alloy double-wall, disc, pin joint, 25mm, 36h
FRONT HUBDisc, alloy, double-sealed, loose ball, steel axle, QR, 36h
REAR HUBDisc, alloy, double-sealed, loose ball, steel axle, steel cassette body, QR, 36h
SPOKESStainless, 14g (2.0mm)
FRONT TIRESpecialized Fast Trak Sport, 29x2.0", wire bead, 40TPI
REAR TIRESpecialized Fast Trak Sport, 29x2.0", wire bead, 40TPI
INNER TUBESStandard Schrader valve
SADDLESpecialized Body Geometry Hardrock, steel rails, 143mm
SEATPOSTAlloy, 2-bolt, micro-adjust, 12.5mm offset, 30.9mm, 350mm/400mm
SEAT BINDERForged alloy, 34.9mm, QR, nylon washer
sergijtrupp
Re: Продам Specialized Hardrock
Повідомлення sergijtrupp » 10.6.14 06:24
Куплений 14.04.2014. Рік випуску 2014. Новий такий коштує 8339грн. Є чек, гарантія, інструкція
sergijtrupp
Повідомлення sergijtrupp » 22.6.14 09:09
Велосипед ще чекає на нового власника
behemot
З нами з:18.5.14 08:08
Повідомлення behemot » 27.6.14 18:07
Добрый день.если подкоректируете цену то интересен.от нового обычно теряет 25%,получается 6200.с уважением
