Specialized Hardrock Comp Disk 2006
Andrushencio
З нами з:26.10.08 09:39
Повідомлення Andrushencio » 28.9.15 13:27
Цена: 11000 (реальному покупателю реальный торг)
Год выпуска: 2006
Телефон для связи: 093-796-58-76 Aндрей
Frame & Fork
Frame Construction TIG-welded
Frame Tubing Material A1 Premium Aluminum
Fork Brand & Model Marzocchi MZ-3, 100mm
Fork Material Magnesium/aluminum/steel, single crown
Rear Shock Not applicable
Components
Component Group SRAM Mix
Brakeset Hayes HMX-2 XC, mechanical disc with 6" wave cut rotor brakes, Hayes HML-1 levers
Shift Levers SRAM SX-7 trigger, 8-speed
Front Derailleur SRAM 3.0, 34.9mm clamp, top swing, botttom pull
Rear Derailleur SRAM SX-5, 8-speed, mid cage
Crankset Truvativ ISO-Flo, Power Spline, alloy, capless bolts, 22t/32t heat treated Cro-Mo/42t Cro-Mo teeth
Pedals Specialized alloy platform with 9/16" Cr-Mo spindle
Bottom Bracket Truvativ Power Spline, 113mm spindle
BB Shell Width 68mm English
Rear Cogs 8-speed, 11 - 32 teeth
Chain Shimano CN-IG31
Seatpost Alloy micro adjust, 30.9mm diameter
Saddle Specialized Body Geometry Sport MTB
Handlebar Alloy, 38mm rise, 6 degree upsweep, 8 degree sweep, 640mm width
Handlebar Extensions Not included
Handlebar Stem Specialized Mobius, alloy, 10 degree rise
Headset 1 1/8" threadless, sealed ball retainer
Wheels
Hubs Front: Joy-Tech, disc, ground race double sealed loose ball w/ alloy QR, Rear: Joy-Tech, disc cassette, ground race double sealed loose ball
Rims SUN DitchWitch, 36-hole
Tires 26 x 2.20" Specialized Enduro Sport, wire bead
Spoke Brand Stainless steel, 14ga. (2.0mm) straight gauge
Spoke Nipples Brass nipples
