Specialized Myka
MarinaChin
З нами з:23.3.11 23:33
Specialized Myka
Повідомлення MarinaChin » 29.5.11 21:24
Продам женский велосипед Specialized Myka 2009 г.в. выезжал 2 раза. Инструкция, гарантийный талон. По причине отьезда, нет возможности взять с собой. Ц. 3000 грн.
Фото:
http://i.piccy.info/i5/55/11/1561155/25052011064.jpg
http://i.piccy.info/i5/57/11/1561157/25052011065.jpg
http://i.piccy.info/i5/59/11/1561159/25052011067.jpg
http://i.piccy.info/i5/61/11/1561161/25052011068.jpg
http://i.piccy.info/i5/64/11/1561164/25052011069.jpg
http://i.piccy.info/i5/70/11/1561170/25052011071.jpg
http://i.piccy.info/i5/71/11/1561171/25052011072.jpg
http://i.piccy.info/i5/73/11/1561173/25052011073.jpg
http://i.piccy.info/i5/76/11/1561176/25052011074.jpg
http://i.piccy.info/i5/77/11/1561177/25052011075.jpg
Спецификация:
FRAME Myka A1 Premium Aluminum, fully butted, women's geometry, low standover TT, ORE DT, externally relieved HT, forged dropouts w/ replaceable alloy hanger
FORK SR Suntour SF11-XCT-V3-P-26, 80mm, 1pc. alloy lower, 28mm Hi-Ten stanchions, coil/mcu spring w/ preload adj.
HEADSET 1-1/8" threadless, loose ball
STEM Alloy A-head, 4 bolt, 20 degree rise, 25.4mm clamp
HANDLEBARS Hi-Ten riser bar, 32mm rise, 8 degree back sweep, 6 degree up
GRIPS Specialized Myka, dual density Kraton, 130mm
FRONT BRAKE "V" brake, alloy linear pull, 1pc. pad
REAR BRAKE "V" brake, alloy linear pull, 1pc. pad
BRAKE LEVERS Alloy, linear pull
FRONT DERAILLEUR Shimano FD-M310 Altus, 34.9mm clamp
REAR DERAILLEUR SRAM X.4 8sp Midcage
SHIFT LEVERS SRAM X.3 7sp trigger
CASSETTE SRAM PG-730, 7-speed, 12-32t
CHAIN KMC Z7 w/ reuseable Missing Link
CRANKSET SR SunTour, square taper spline
CHAINRINGS 42S x 32S x 22S replaceable outer
BOTTOM BRACKET Sealed cartridge, square taper, 118mm
PEDALS Composite body, reflectors, toe clip compatible, 9/16"
RIMS Alex HR 26", alloy double wall, pinned, 32h
FRONT HUB Forged alloy, double sealed, ground race, QR, 32h
REAR HUB Forged alloy, double sealed, ground race, cassette, QR, 32h
SPOKES 2mm (14g) stainless
FRONT TIRE Specialized Fast Trak LK Sport, 26x2.0", 60TPI, wire bead
REAR TIRE Specialized Fast Trak LK Sport, 26x2.0", 60TPI, wire bead
INNER TUBES Schraeder valve
SADDLE Body Geometry Women's Riva MTB, 155mm width
SEATPOST Alloy two bolt, 12.5mm offset, micro adjust, 30.9mm
SEAT BINDER Alloy QR, nylon washer
NOTES Chain stay protector, reflectors, clear coat, owners manual
093 5868473
Maks&Bike
З нами з:14.2.11 02:24
Re: Specialized Myka
Повідомлення Maks&Bike » 29.5.11 22:12
Бронь до выяснения. Завтра позвоню, так как сегодня уже поздно.
Kryshchik
З нами з:4.3.11 15:41
Повідомлення Kryshchik » 30.5.11 08:30
В продаже еще???
Maks&Bike
Повідомлення Maks&Bike » 30.5.11 14:20
Велосипед еще в броне за мной.
Продавец не снимает трубку..:(...буду звонить еще раз.
MarinaChin
Повідомлення MarinaChin » 30.5.11 21:35
еще в продаже.
093 5868473
MarinaChin
Повідомлення MarinaChin » 6.6.11 21:46
Велосипед продан, всем спасибо.
093 5868473
