нормальный будет для стрита\дерта?
element0
З нами з:12.5.11 18:54
Повідомлення element0 » 12.5.11 19:12
Felt Jump Shot (2010)
Год: 2010
Производитель: Felt
Рама: Felt Jump Shot Design, 6061 Aluminum, Hydroform Top Tube, 565mm TTL, MTB Vertical Dropouts, with USA BB Shell & 2-Bolt Intergrated Design Eccentric BB Set, Disc Brake Only, Replaceable Derailleur Hanger (Dummy Hanger included as OEM), Ultra Short Stays
Вилка: Marzocchi DJ 3 100mm, Fixed Damping Coil Spring, Reinforced Steel Steerer and Stanchions for 20mm axle
Задний амортизатор: N/A
Система: Truvativ Ruktion Heat-Treated Steel 34T Single Chainring, 170mm
Тормоза: Hayes MX-2HD Mechanical 180mm Rotor Front, Hayes MX-2XC Mechanical 160mm Rotor Rear
Тормозные ручки: Hayes
Передний переключатель: N/A
Задний переключатель: SRAM X-9 Mid-Cage
Манетки (ручки переключения): N/A
Втулка передняя: Felt 20mm Thru Axle Cold-Forged Aluminum Body, 32H Disc Brake
Втулка задняя: FELT Custom, Single Speed Specific Cassette Freehub, for Disc brake, 2 Cartridge Bearing Design for 6-bolt Rotor, Black Anodized with Nutted Axles
Обода: WTB Speed Disc XL Disc Doublewall Aluminum, 26 x 1.5 x 36H, 32mm Width, Black Anodized, with Single Eyelets, with WTB Decal
Покрышки: Kenda K-Rad Dirt Dirt Jump tire 26 x 2.3 30 TPI Wire Bead
Седло: Felt Dirt Jump BMX, 3-Piece Cover, 7mm Cr-Mo Rails
Подседельный штырь: Felt Two-Bolt Alloy Micro-Adjust, 100% Black, 30.9x250mm, 300g
Педали: Felt Backpedal Alloy Platform
Кассета: 19 Teeth Cassette Sprocket
Руль: FELT All Mountain Handlebar Butted Oversize 6061 Aluminum, 31.8mm clamp diameter, 35mm Rise, 8 degree bend with 4 degree sweep, Width: 680mm
Вынос: FELT DJ stem, 3D Forged Alloy, 4-bolt design, 31.8 Bar Bore, 50mm Extension
Рулевая колонка: Super-Semi-Integrated, 1-1/8 Aheadset, 12mm Deep Cr-Mo Cups, Oversized 3/16 Caged Bearing, with Alloy Laser Top Cap, 2 x 5mm Straight Washers
Ручки руля (грипсы): Felt AM Grip Custom LOCK-ON Design with Alloy Ends Single-Density Extra-Soft & Sticky (Recipe #25) Durometer, 130mm Length, 30mm OD
Размеры рамы: S
Цвет: Rust Brown Metallic
нормальный будет для стрита\дерта? альтернатива?
