Giant REVEL 0 vs. Author Dexter
mutyonok
З нами з:6.4.11 14:33
Повідомлення mutyonok » 8.4.11 18:21
Подскажите какой велосипед лучше выбрать:
5 456 грн - Giant REVEL 0:
FRAME
Sizes XS, S, M, L, XL, 2XL
Colors Black/Green
Frame ALUXX-Grade Butted Aluminum
Fork RockShox Dart 2, 100mm Travel
Shock N/A
COMPONENTS
Handlebar Giant Sport Alloy, Low Rise 31.8
Stem Giant Sport, Alloy
Seatpost Giant Sport, Alloy, 30.9
Saddle Giant Sport MTB
Pedals Alloy Platform
DRIVETRAIN
Shifters SRAM X.5, Trigger
Front Derailleur Shimano Altus
Rear Derailleur SRAM X.5
Brakes Avid BB5 Disc
Brake Levers Tektro Alloy, 2 Finger
Cassette SRAM PG830 11x32, 8-Speed
Chain KMC Z72
Crankset Shimano Acera M361, 22/32/42
Bottom Bracket Shimano Cartridge
WHEELS
Rims Giant XC Alloy, Double Wall
Hubs Formula Disc, 32h
Spokes Stainless Steel, 14g
Tires Kenda Small Block Eight, 26x2.1
OTHER
Weight How much does this bike weigh? It’s a common question, and rightly so. But the truth is, there are no industry standards for claiming bike weights—and this leads to a lot of misinformation. Variances exist based on size, frame material, finish and hardware. And as bikes get lighter, these differences become more critical. At Giant, we believe the only way to truly know the weight of any particular bike is to find out for yourself at your local retailer.
5 160 грн - Author Dexter:
dexter
МОДЕЛЬ DEXTER
РАЗМЕРЫ РАМ 15", 17", 19", 21", 23"
МАТЕРИАЛ РАМЫ alloy 6061 26"
ПЕРЕДНЯЯ ВИЛКА "RST Gila Pro TnL oil, lock out (100 mm)"
РУЛЕВАЯ КОЛОНКА "FSA Integrated 1-1/8"" "
ШАТУНЫ "SUNTOUR XCR-T414 44-32-22 170 / 175 mm cranks"
КАРЕТКА "SUNTOUR XCM cartridge"
ПЕРЕДНИЙ ПЕРЕКЛЮЧАТЕЛЬ "SHIMANO Alivio (34.9)"
ЗАДНИЙ ПЕРЕКЛЮЧАТЕЛЬ SHIMANO Alivio
МАНЕТКИ SHIMANO Alivio (27)
КАССЕТА "SHIMANO HG-30-9 11-32 (9)"
ЦЕПЬ SHIMANO HG-53
ВТУЛКИ "QUANDO Disc 32 holes "
ТОРМОЗА "TEKTRO Draco disc hydraulic (6"" rotors)"
ТОРМОЗНЫЕ РУЧКИ TEKTRO Draco
ОБОДА "JALCO ATB 220 black doublewall 32 holes"
СПИЦЫ black steel
ПОКРЫШКИ "MAXXIS Copper Head 26"" x 2.00"""
ПЕДАЛИ "AUTHOR alloy / resin"
РУЛЬ "KALLOY 15 mm 31.8 mm"
РОГИ "AUTHOR high density foam"
ГРИПСЫ KALLOY alloy
ВЫНОС "KALLOY alloy (31.6)"
ПОДСЕДЕЛЬНАЯ ТРУБКА (ГЛАГОЛ) AUTHOR (34.9)
ЗАЖИМ СЕДЛА AUTHOR alloy QR
СЕДЛО AUTHOR Mega Top
КОЛИЧЕСТВО ПЕРЕДАЧ 27
МАССА (кг) 14.0 Kg / 19"
Про себя:
Катать по лесу, велопоходы по пересеченке.
Вес 60 кг
Рост 175.
Востаннє редагувалось 10.4.11 13:26 користувачем mutyonok, всього редагувалось 1 раз.
Pooh
З нами з:5.6.03 09:48
Re: Giant REVEL 0 vs. Author Dexter
Повідомлення Pooh » 9.4.11 15:39
Я бы не смотрел на то, что Dexter на гидравлике и 9-рике, а добавил бы денег и взял Revel за то, что у него качественные механические дисковые тормоза и вилка, а еще и 8-рик. И еще он просто симпатичнее ;)
Если не сложно, скажите из какого Вы города - возможно сможем еще что-то предложить в той же ценовой категории.
Повідомлення Трям » 9.4.11 16:57
А в-брейков для походов не хватит ? :gerl:
И вел легче и оборудование не хуже. И останутся деньги на очки, шлем, памперс и велокомп (с 50% скидкой) *oops*
http://www.kellys.com.ua/bike.php?b=kel ... 0%CD%DB%C9
mutyonok
Повідомлення mutyonok » 9.4.11 21:24
Киев,
На в-бряках накатался уже :)
ПС. Ходил в веломагаз гиантов не оказалось - предложили посмотреть Cannondale Trail 5
  • Рама : Trail, баттированная, сплав 6061
  • Вилка : RST Gila Pro TNL, пружинная, ход 100 мм, с гидравлической блокировкой
  • Руль : Cannondale C4, гнутый, сплав 6061, двойной баттинг, длина 660 мм
  • Вынос : Cannondale C4, 31.8 мм
  • Подседельный штырь : Cannondale C4, 31.6 мм
  • Седло : Cannondale Stage 2
  • Педали : FPD Platform
  • Переключатели : Shimano Aliviо, 24 скорости
  • Передняя перекидка : Shimano FD-M311
  • Задняя перекидка : Shimano Aliviо
  • Тормоза : Promax Orange, дисковые, механические, ротора 160 мм
  • Тормозные ручки : Promax Orange
  • Кассета : Sunrace, 8-ми скоростная, звезды 12-32Т
  • Цепь : KMC Z-72
  • Шатуны : Shimano FC-M311, звезды 22/32/42T
  • Каретка : Tange Seiki LN-3912
  • Обода : Alex DC 4.5, двойные, под диск
  • Втулки : Formula CDH20/CDH22, 32 отверстия, под 6 болтов
  • Спицы : Stainless Stell
  • Покрышки : Kenda Small Block 8, 26х2.1
плюсы: Весит 13 кг, кэннондэйл, вилка лучше чем у Giant, цена 5200грн
минусы: Асера, стремные тормоза (или нет?)
В общем я начинаю теряться :)
mutyonok
Повідомлення mutyonok » 10.4.11 13:25
всем спасибо, купил Cannondale!
