Specialized Hardrock Disc 2011 VS Gary Fisher 2011 Advance D
Повідомлення dem80 » 16.3.11 11:09
Помогите с выбором велосипеда
Gary Fisher 2011 Advance Disc
Описание
Фреймсет
Размеры 13, 15.5, 17.5, 19, 21
Рама Gold Series 6061 T6 aluminum, G2 geometry, butted and hydroformed tubing, cold-forged dropouts & bottom bracket
Вилка SR Suntour SF10 XCT-V2 100 w/lockout, custom G2 geometry, 46mm offset crown, 100mm
Колеса
Втулки Formula DC20 front hub, Shimano M475 rear hub
Обода Bontrager 550 Disc, 36-hole rims
Покрышки Bontrager LT3 ECO, 26x2.0
Ходовая
Манетки Shimano EF51, 8 speed
П.переключатель Shimano M190
З.переключатель Shimano Alivio
Система Shimano Tourney, 42/34/24
Кассета SRAM PG-820 11-32, 8 speed
Педали Wellgo LU-984, boron axle, toe clip adapter
Компоненты
Тормоза Tektro Novela, mechanical disc, 6-bolt , 160mm rotors
Седло Bontrager SSR
Подседельный штырь Bontrager SSR, 27.2mm, 20mm offset
Вынос Bontrager Approved
Руль Bontrager Approved Riser, 30mm rise, 9 degree sweep
Грипсы Bontrager SSR
Рулевая 1-1/8 threadless, semi-integrated, semi-cartridge bearings
Доп.оборудование Tektro Novela, mechanical disc, 6-bolt
Цена 4440 грн.
FRAME Specialized A1 Premium Aluminum, fully butted, formed TT, Double ORE DT, externally relieved HT, reinforced disc mount, forged dropouts w/ replaceable hanger, disc only
FORK SR Suntour SF11-XCT-V3-DS-26, 80mm, 1pc. alloy lower, 28mm Hi-Ten stanchions, coil/mcu spring w/ preload adj.
HEADSET 1-1/8" threadless, loose ball
STEM A-head, 15 degree rise, 25.4mm clamp
HANDLEBARS Hi-Ten riserbar, 35mm rise, 8 degree back sweep, 4 degree up
GRIPS Specialized Enduro, dual compound Kraton, no flange, 131mm
FRONT BRAKE Tektro IO Mechanical disc brake, dual pad angle adj., 160mm rotor
REAR BRAKE Tektro IO Mechanical disc brake, dual pad angle adj., 160mm rotor
BRAKE LEVERS Alloy, linear pull
FRONT DERAILLEUR Shimano Altus, 34.9mm clamp
REAR DERAILLEUR SRAM X.4 8sp Midcage
SHIFT LEVERS SRAM X.3 7sp trigger
CASSETTE SRAM PG-730, 7-speed, 12-32t
CHAIN KMC Z7 w/ reuseable Missing Link
CRANKSET SR SunTour, square taper spline
CHAINRINGS 42S x 32S x 22S replaceable outer
BOTTOM BRACKET Sealed cartridge, square taper, 68/118mm
PEDALS Composite platform, toe clip compatible, 9/16" w/ reflectors
RIMS Alex HRD 26", alloy double wall, pinned, 32h
FRONT HUB Forged alloy, double sealed, ground race, QR, disc, 32h
REAR HUB Forged alloy, double sealed, ground race, QR, disc, cassette, 32h
SPOKES 2mm (14g) stainless
FRONT TIRE Specialized Fast Trak LK Sport, 26x2.0", 60TPI, wire bead
REAR TIRE Specialized Fast Trak LK Sport, 26x2.0", 60TPI, wire bead
INNER TUBES Schraeder valve
SADDLE Specialized XC, Body Geometry, 143mm width, front and rear bumpers
SEATPOST Alloy two bolt, 12.5mm offset, micro adjust, 30.9mm
SEAT BINDER Alloy QR, nylon washer
NOTES Chain stay protector, reflectors, clear coat, owners manual
4399 грн
Выбираю велосипед для:
1. Поездок по городу
2.Поездок по парку
3.Поездок по пересечённой местности
Нужна скорость, приемистость и проходимость
