Продам Specialized Rockhopper Expert Disc '09 новый
pasha-zvet
З нами з:20.1.11 15:29
Повідомлення pasha-zvet » 12.3.11 12:23
Specialized Rockhopper Expert Disc '09 (S, 15) s/n P8JJU0580
Рама: Specialized M4 Manipulated Alloy frame, fully butted, ORE DT, forged dropouts w/ replaceable 98954020 hanger, disc only
Вилка: Rock Shox Tora SLite, 100mm, alloy steerer, 32mm Cr-Mo stanchions, magnesium lower, coil spring preload and rebound adj. w/ LO, 13-15": standard spring, all others: "stiff" spring w/ preload adj., disc only
Рулевая колонка: Specialized 1-1/8" threadless, loose ball
Вынос: Specialized 3D forged, 4-bolt, 7 degree rise, 31.8mm clamp
Руль: Specialized butted alloy, 31.8mm, 25mm rise, 640mm wide, 8 degree back sweep, 8 degree up, 2.6mm thick
Грипсы: Specialized Enduro, dual compound Kraton, no flange, 131mm
Передний торомоз: Tektro Auriga Comp, hydraulic disc, dual piston w/ 160mm rotor
Задний торомоз: Tektro Auriga Comp, hydraulic disc, dual piston w/ 160mm rotor
Тормозной рычаг: Tektro Auriga Comp
Передний переключатель: Shimano Deore, 34.9mm clamp, bottom swing, dual pull
Задний переключатель: Shimano Deore
Манетки: Shimano Deore SL- M531, 9-speed
Кассета: Shimano HG-50, 9-speed, 11-34t
Цепь: KMC X9 w/ reuseable Missing Link
Система: Shimano FCM442, forged alloy arms, Octalink Spline w/ replaceable rings
Передняя звезда: 44A x 32S x 22S
Каретка: Shimano BB-ES25, Octalink spline, cartridge bearings, 68mm x 118mm
Педали: Alloy body and cage, 9/16"
Обода: Specialized RHD 26", double wall disc, pinned w/ eyelets, 28/32h
Передняя втулка: Specialized Hi Lo, forged alloy, double sealed, ground race, 28h
Задняя втулка: Specialized, forged alloy, double sealed, ground race, cassette, QR, 32h
Спицы: 1.8mm (15g) stainless
Передняя покрышка: Specialized Fast Trak Control, 26x2.0", 60TPI, aramid bead, 2Bliss ready
Задняя покрышка: Specialized Fast Trak Control, 26x2.0", 60TPI, aramid bead, 2Bliss ready
Камера: Specialized schraeder valve
Седло: Specialized Indie XC, Body Geometry, 143mm width, front and rear bumpers
Подседельный штырь: Specialized alloy two bolt, micro adjust head, 30.9mm
Цвет: Серебро
Новый, с документами и гарантией. Стоимость велосипеда 6900 грн., рама + вилка 3900 грн.
Продам Камуфляж НАТО новый - 250 грн
Зараз переглядають цей форум: Немає зареєстрованих користувачів і 56 гостей
