Frame - Scott Scale Alloy 6061
custom butted superlight tubing
D-Forged CNC machined Dropouts
Delta SST bridge / Integ. HT
BOX chainstay bridge
Fork - Suntour XCR
alloy steerer
coil spring
lockout
100mm travel
Headset - Ritchey OE 1 1/8"
semi integrated
44/50mm
Derailleur (Rear) - Shimano SLX
RD-M660 SGS
Shadow Type
27 Speed
Derailleur (Front) - Shimano Deore
FC-M590
34.9mm
Shifters - Shimano Deore
SL-M590
Rapidfire plus
2 way release
w/gear indicator
Brake Levers - Shimano
BL-M486 Disc
Brakes - Shimano
BR-M486 Disc
160/F and
160/R mm Rotor
Crankset - Shimano
FC-M442
Octalink
44x32x22 T
BB-Set - Shimano
ES25 Octalink
68-118mm
Handlebar - Scott Pilot 18 Team
18mm rise
OS / 640mm
H'stem - Scott Comp
4 Bolt / OS 31.8mm
1-1/8" / 6° angle
Pedals - Wellgo C128
Seatpost - Scott Comp
31.6mm
Seat - Scott Racing
Hub (Front) - Scott Team
Disc CL
Hub (Rear) - Shimano
FH-RM65
Disc CL
Chain - Shimano
CN-HG53
Cassette - Shimano
CS HG-50-9
11-32 T
Spokes - Stainless Black
15G / 1.8mm
Rims - Alex XC-44
Disc
32H / Eyelets
Black
Tires - Schwalbe
Rocket Ron
26 x 2.1 / 50EPI
Performance Series
Fork - Suntour XCR
alloy steerer
coil spring
lockout
100mm travel
semi integrated
44/50mm
RD-M660 SGS
Shadow Type
27 Speed
FC-M590
34.9mm
SL-M590
Rapidfire plus
2 way release
w/gear indicator
BL-M486 Disc
Brakes - Shimano
BR-M486 Disc
160/F and
160/R mm Rotor
Crankset - Shimano
FC-M442
Octalink
44x32x22 T
BB-Set - Shimano
ES25 Octalink
68-118mm
18mm rise
OS / 640mm
H'stem - Scott Comp
4 Bolt / OS 31.8mm
1-1/8" / 6° angle
31.6mm
Seat - Scott Racing
Disc CL
FH-RM65
Disc CL
Chain - Shimano
CN-HG53
Cassette - Shimano
CS HG-50-9
11-32 T
15G / 1.8mm
Rims - Alex XC-44
Disc
32H / Eyelets
Black
Tires - Schwalbe
Rocket Ron
26 x 2.1 / 50EPI
Performance Series
2. Jamis Durango 2
7005 triple-butted aluminum main tubes, over-sized seat tube, sloping radius top tube, box-section down tube at BB, zero-stack head tube, over-sized stays, replaceable derailleur hanger
Fork
RST Omega TnL, magnesium sliders, lockout, 30mm stanchions, 100mm travel
Headset
Zero-stack internal cup threadless, 20mm shim stack, 1 1/8”
Wheels
Alex DP17 double-wall/eyeletted disc-specific rims, 32H, Formula alloy disc hubs, 14g black stainless steel spokes
Tires
Geax Barro Mountain, 26 x 2.1”
Derailleurs
Shimano SLX Shadow rear, Shimano New Deore 34.9mm top pull front
Shiftlevers
Shimano Deore RapidFire-SL, 27-speed
Chain
KMC Z9000
Cassette
Sram PG-950, 9-speed, 11-32
Crankset
Shimano Deore M442 Octalink, 44/32/22, 170mm (12-15.5”), 175mm (17-21”)
BB Set
Shimano ES25, Octalink, 68 x 118
Pedals
Alloy platform with steel outer cage
Brakeset
Tektro Auriga Comp hydraulic disc brakes with 6” wavy rotor
Handlebar
Jamis XC alloy riser, 6º sweep x 13mm rise x 620mm wide
Stem
Jamis XC alloy threadless, 10º rise, x 75mm (13” ), 90mm (15”), 100mm (17”), and 120mm (19-21”)
Grips
Velo Kraton, medium diameter
Seat Post
Jamis alloy micro-adjust, 31.6 x 350mm, with alloy QR clamp
Saddle
Jamis Trail with pressure relief channel, wide tail platform and scuff-resistant corners
Sizes
13”, 15”, 17”, 19”, 21”
Color
GunMetal/Flat Black or Copper/Pearl White
Weight
30.75 lbs
Fork
Headset
Wheels
Tires
Derailleurs
Shiftlevers
Chain
KMC Z9000
Cassette
Crankset
BB Set
Pedals
Brakeset
Handlebar
Stem
Grips
Seat Post
Saddle
Sizes
Color
Weight
30.75 lbs
