продам Specialized Hardrock Sport Custom `08
arthur_a86
З нами з:5.9.08 08:41
Повідомлення arthur_a86 » 12.8.10 06:14
Продам Specialized Hardrock Sport 2008года.
Пробег около 1000-1500км. Катал асфальт (60%) и лесовые дороги (40%). Рама не повреждена, мелкие царапины в области пера от цепи (по началу ездил без защиты). Велосипед черный с желтыми полосами. Рама 21" размера. Велосипед покупался в ExtremStyle на Глубочицкой новым.
Стоковая спецификация
FRAME
A1 Premium Aluminum, double-butted, ORE DT, externally relieved HT, reinforced disc mount, forged dropouts w/ replaceable 98954020 alloy hanger
REAR SHOCK
N/A
FORK
SR Suntour SF7-XCM, 100mm travel, 12": 80mm, 30mm Hi-Ten stanchions and steerer, one piece alloy lower, coils spring mcu w/ preload adj., spring assisted seals, custom paint/graphic
HEADSET
1 1/8" threadless
STEM
Specialized 3D forged alloy, two bolt, 25.4mm, 10 degree rise
HANDLEBARS
Alloy 25.4mm, 640mm wide, 38mm rise, 8 degree back, 6 degree up sweep, 3.2mm thick
TAPE/GRIPS
Specialized Enduro, dual density Kraton
FRONT BRAKE
Pro Max, alloy "V" w/ linear spring
REAR BRAKE
BRAKE LEVERS
Shimano EF-50, integrated
FRONT DERAILLEUR
Shimano Altus FD-M310-6, top swing, 34.9mm clamp
REAR DERAILLEUR
Shimano Acera RD-M340
SHIFT LEVERS
Shimano EF-50
CASSETTE FREEWHEEL
Shimano HG-40, 8-speed, 11-32t
CHAIN
KMC X8, 1/2" x 3/32" w/ reusable Missing Link
CRANKSET
SR Suntour XCM-T312, replaceable rings, Octalink spline
CHAINRINGS
42S/32S/22S
BOTTOM BRACKET
Shimano BB-ES25, Octalink spline, cartridge bearing, 68 x 118mm for 50mm chainline
PEDALS
Steel cage, composite body, 9/16"
RIMS
Specialized/Alex HR 26, double wall w/ CNC
FRONT HUB
Specialized, forged alloy, 32h, polished races, steel QR
REAR HUB
Shimano FH-RM30L, cassette, 32h, QR
SPOKES
1.8mm (15g) stainless
FRONT TIRE
Specialized Resolution, 26x2.1", 30TPI, wire bead
REAR TIRE
TUBES
Specialized schraeder valve
SADDLE
Specialized Aggro, Aramid sides, front and rear bumpers, 143mm width
SEAT POST
Specialized alloy two bolt micro adjust head, 30.9mm
SEAT BINDER
Specialized alloy w/ QR
NOTES
Chain stay protector, reflectors, clear coat, owners manual
Что заменено:
- в связи с тем что вел переоборудовал на гидравлику установлено:
1. Передняя втулка Novatec D041SB
2. Задняя втулка Formula (Какая точно - не вспомню, покупал где то за 300грн)
3. Манетки Sram 2009 Attack Trigger 2:1 (стоковые манетки были интегрированые с тормозными ручками)
4. Собственно тормоза спереди и сзади Avid 2009 Juicy 3 с 160мм роторами
- аксесуары:
5. Велокомп Cat Eye Enduro 8
6. Фара Cat Eye HL-EL-300G
7. Задняя моргалка на 5 диодов
8. Флягодержатель BBB
9. Ручной насос
10. Подсидельная сумка
11. Усилил колеса от внутринних проколов спицами защитными лентами Мишлен.
- Также есть инструменты, очки и велошлем VK.
Велосипед в рабочем состоянии, есть небольшие поскрипывания в области вилки.
Ориентировочная желаемая стоимость за весь комплект - 3900грн.
ICQ 44з-62о-з5о
тел. о67-5оо-96-5(три) Артур
фото
arthur_a86
Re: продам Specialized Hardrock Sport Custom `08
Повідомлення arthur_a86 » 14.8.10 08:48
3800грн
arthur_a86
Повідомлення arthur_a86 » 16.8.10 21:00
3600грн (велосипед со всем навесным + инструменты + шлем ВК)
arthur_a86
Повідомлення arthur_a86 » 18.8.10 20:57
3500грн!
lester
З нами з:5.6.10 00:10
Повідомлення lester » 21.8.10 19:25
интересует вел пока забиваю до выяснения, сколько еще готовы скинуть, и как с отправкой в другой город в лс
arthur_a86
Повідомлення arthur_a86 » 30.8.10 14:05
Всем спасибо, вел продан
