[Продан]Specialized 2007 P1
flyyer
З нами з:17.9.09 16:21
Повідомлення flyyer » 15.7.10 15:12
Specialized 2007 P1:
1.РАМА Specialized 100% Cr-Mo, double-butted HT/DT, externally relieved HT, disc mount, 6mm offset horizontal drop out for 26" wheel w/ replaceable der hanger adapter
2.ВИЛКА Marzocchi DJ 3.5, 100mm, 32mm Cro-Mo stanchions and 1 1/8" steerer, coil spring w/ air assist, rebound adjustment, magnesium lowers, standard axle dropout
3.РУЛЕВАЯ КОЛОНКА Tank FS, 1 1/8" threadless
4.ВЫНОС Truvativ Hussefelt, forged alloy, 31.8mm, 0 degree rise
5.РУЛЬ Alloy OS, 640mm wide, 45mm rise, 8 degree backsweep, 6 degree upsweep
6.ГРИПСЫ Specialized Enduro, dual density, Kraton
7.ТОРМОЗ задний Avid BB5, mechanical disc, 6" G2 Clean Sweep rotor
8.ТОРМОЗНЫЕ РУЧКИ Avid FR-5, alloy "V"
9.КАССЕТА 1/2"x3/32"x16t Cr-Mo cog w/ Shimano spline and conversion spacers
10.ЦЕПЬ KMC Z-610H, 1/2" x 3/32"
11.ШАТУНЫ Truvativ Ruktion, 6061, 175mm, Howitzer spline w/ pedal thread inserts
12.ЗВЕЗДЫ ШАТУНОВ 32S w/ poly bash guard
13.КАРЕТКА Truvativ Howitzer XR, sealed cartridge bearings, 73mm Shell for 52mm chainline
14.ПЕДАЛИ Specialized alloy platform, 9/16"
15.ОБОДА Specialized/Alex HRD 26, double wall disc w/ eyelets
16.ПЕРЕДНЯЯ ВТУЛКА Specialized P.Disc, CNC high flanges and disc mounts, 36h, nutted 3/8" axle
17.ЗАДНЯЯ ВТУЛКА Specialized P.Disc, cassette, CNC high flanges and disc mounts, 36h, nutted 3/8" axle
18.СПИЦЫ 2.0mm (14g) stainless
19.ПЕРЕДНЯЯ ПОКРЫШКА Specialized Rhythm, 26x2.3", 60TPI, wire bead
20.ЗАДНЯЯ ПОКРЫШКАSpecialized Compound, 26x2.2", 60TPI, wire bead
21.СЕДЛО Fuse 8 Jumping
22.ПОДСИДЕЛЬНЫЙ ШТЫРЬ Alloy micro adjust, 30.9mm
23.ЗАЖИМ ПОДСИДЕЛЬНОГО ШТЫРЯ CNC'd alloy, single bolt
Катал только в магазин по хлеб..состояние на 5-!! ЦЕНА 2500
тел.8 063 721 39 60 Никита
flyyer
Re: Продаю Specialized 2007 P1
Повідомлення flyyer » 15.7.10 22:58
точная копия.....)) только нехватает у меня передних тормозов..
flyyer
Повідомлення flyyer » 30.7.10 12:48
UP!!!!!!!!
Parico
З нами з:14.5.10 14:27
Повідомлення Parico » 30.7.10 18:34
передний тормоз возможно поставить обратно или продан?
п.с. если есть - то заинтересован...
Gari4ello
З нами з:27.4.10 23:54
Skype:gari4elloz
Повідомлення Gari4ello » 30.7.10 22:41
а цена в какой валюте...? какая ростовка и цвет? интересно! :good:
Parico
Повідомлення Parico » 31.7.10 10:50
бронь до понедельника!
flyyer
Повідомлення flyyer » 2.8.10 11:47
Тему создавал для малого который и есть владелец... тел. 8 093 056 82 86 (Никита)
Малый чуть тормознутый...!%)
flyyer
Повідомлення flyyer » 4.9.10 14:16
Продано..
