Велосипед Specialized Epic Expert 2008!
msha
З нами з:20.12.09 15:16
Повідомлення msha » 20.12.09 16:30
Продается Specialized Epic Expert 2008!
Рама XL
Стандартная комплектация байка:
Рама:
Epic FSR M5 alloy, fully manipulated frame w/ new larger diameter/stiffer ORE DT/TT, hollow alloy shock link, sealed cartridge bearings, 100mm travel, replaceable derailleur hanger
Амортизатор:
Specialized AFR inertia, Brain Fade, adjustable from HT firm to Trail Tune, air spring, rebound adjust
Вилка:
Fox F100 RL, 100mm travel, air spring, rebound/compression adjust w/ lock out, alloy steerer
Рулевая:
1 1/8" threadless, alloy cups w/ 10mm insertion, sealed cartridge bearing
Вынос:
Specialized adjustable rise, 31.8mm clamp, 3D forged w/CNC finish
Руль:
Specialized XC low rise 31.8mm bar, 2014 butted alloy, 6 degree up, 8 degree backsweep, 640mm wide
Грипсы:
Specialized thin lock on grip, dual density
Тормоза:
Custom Avid Ultimate 7, hydraulic disc, 160/140мм.
Передний переключатель:
Shimano M581 LX, 34.9mm clamp, bottom swing, dual pull
Задний переключатель:
SRAM X-0, 9-speed, mid cage
Манетки:
SRAM X-9, aluminum 9-speed trigger
Кассета:
Shimano HG-50, 9-speed, 11-34t
Цепь:
SRAM PC-971 w/ Power Link
Система:
Shimano M762 XT custom for Specialized
Звезды:
22S/32A/44A, 4 bolt 104/64mm
Каретка:
Педали:
Crank Brothers Smarty custom for Specialized
Обода:
DT Swiss custom for Specialized X420, 24mm w/ eyelets, 28/32h
Передняя втулка:
Specialized Hi Lo disc, 28h CNC flange and disc mount, sealed cartridge bearing, 9mm DT RWS alloy QR
Задняя втулка:
DT Swiss custom for Specialized 370 with DT RWS QR, 32h
Спицы:
DT Swiss Competition 1.8/1.6mm
Покрышки:
Specialized Fast Trak Control LK, 26x2.0", 60TPI, tubeless ready aramid bead, dual compound
Камеры:
Specialized Ultralite, .6mm, presta
Седло:
Specialized XC MTB, hollow Cr-Mo rails, SL foam
Подсёдельный штырь:
2014 butted alloy, single bolt setback, 30.9 x 350/400mm
Зажим подсёдельного штыря:
Alloy collar w/ QR, 34.9mm clamp ID
Барахол не предусмотрен.
Состояние – отличное
Общий пробег – не более 1000 км.
Фото по ссылке http://msha.io.ua/album327760
г. Киев
Цена – 17 000 грн.
Рождественский торг возможен.
Связь ЛС или тел. 0504482855
Максим
msha
Re: Велосипед Specialized Epic Expert 2008!
Повідомлення msha » 10.1.10 14:27
ап от :d_s2:
