В мануале от SUNTOUR есть ответы на многие из прозвучавших вопросов:Подскажите чем смазывать ноги вилки и нужно ли смазывать ее внутри. У меня Suntour Axon D-RL
И еще:Maintenance
SR SUNTOUR forks are designed to be nearly maintenance free. However, as long as moving parts are exposed to
moisture and contamination, performance may be reduced. To maintain high performance, safety and long life, periodic
maintenance is required.
The recommended intervals for maintenance are listed below.
Lubricants and Cleaners:
- Teflon fortified oil
- SR SUNTOUR special grease (SRS No.9170-001) / high quality Teflon fortified grease.
Damping oil:
- SR SUNTOUR special damping oil (SR SUNTOUR special damper oil #PSF01-033 / Viscosity 5W).
MAINTENANCE
Check the fork before each ride and contact your dealer if you have any questions.
Оригинал можно найти и скачать на http://www.srsuntour-cycling.com/After every ride:
- Clean the stanchion tubes and the dustseal area.
After 25 hours:
- Check the main fixing bolts for proper torque (10Nm)
- Oil the dustseal area with Teflon oil or other fork oil
After 50 hours:
- Function check of the fork/Clean and grease service of the bushings at the dealer
After 100 hours:
- Change oil bath and lubricate remote lock and travel adj. beneath cap with Teflon oil
After 100 hours or 1 year:
- Inspection and service of the complete fork at the dealer
Производитель не прав - не слушайте его....After every ride:
Зараз переглядають цей форум: Немає зареєстрованих користувачів і 82 гостей
