Код: Виділити все
_/\_
__
_| |_
| |Код: Виділити все
_/\_
__
_| |_
| |На льду, допустим, одинаково. А на брусчатке, например?и острые и тупые шипы хорошо работают на льду
Слышал жалобы на нокию - теряет шипы. Да и цена...я бы искал Нокиан, невзирая на форму шипов, и был бы спокоен.
http://mtbr.com/reviews/Tire/product_124258.shtmlNokian Hakka WXC300
I broke them in according to the manufacturers instructions (30 road miles), then I took an easy 7 mile ride on some snow covered (~6") trails through the woods. A portion of the trail was rocky, with some roots and log crossings, all covered in snow. I even rode around a frozen pond. That is where studded tires rule. Temperature 21°F
After the ride, I inspected the tires: 1 stud was missing from the front tire, and TWENTY-TWO (22) studs were missing from the rear! At least one stud in the rear was turned on its side. And I was riding easy because I did not want to pull any studs out.
I posted a message the usenet news group rec.bicycles.tech and found another user who experienced the same problem with the HAKKA WXC300. He recommended nokian extremes as a more reliable tire.
At this rate, I could shed all the studs in 100 miles. I expect more from a tire than costs more than any tire I have bought for my car, van, truck; and I get over 50,000 high-speed miles from them. I have used light weight sticky race tires that last only half a season, but these will be dangerous (useless) on ice after a few rides. Ridiculous!
В городе на льду или плотно утоптанному на дорогах/тротуарах снегу разница существенна - комфортнее и безопаснее с железными шипами,хотя многое зависит от пилотаСкажите, существенная ли разница между между широкими злыми шинами с агрессивным протектором и зимними покрышками с металлическими шипами. Ато один продавец говорит, что по льду и на тех и на других не поездишь
нинасколько - зарываюцца, по аналогии с песком стоит подбирать резину для снега.Скажите, насколько эфективны во время катания по рыхлому и утрамбованному снегу узкие покрышки (1.90) с шипами, например Scwalbe Mountaineer 2 . По-моему, они сильно "вгрызаются" в поверхность.
Блин, недавно продавец мне впарил эти покрышки и сказал, что это будет в самый раз для моих целей, мотивируя это тем, что широкие покрышки сильно гасят скорость. Вот урод! А я чувствую, что на них тяжело ездить!нинасколько - зарываюцца, по аналогии с песком стоит подбирать резину для снега.Скажите, насколько эфективны во время катания по рыхлому и утрамбованному снегу узкие покрышки (1.90) с шипами, например Scwalbe Mountaineer 2 . По-моему, они сильно "вгрызаются" в поверхность.
Ну, есть же-ж два подхода к грязевым шинам.Единственное, наверное Mountaineer2 не совсем подходят для катания по грязи, так как сильно погружаются в грязь.
