Specialized Hardrock Sport Disc 29 int 10000 грн.
Запчастини та велосипеди
dvladb
З нами з:17.5.12 20:42
Повідомлення dvladb » 6.12.16 14:39
Продаю свой велосипед Specialized Hardrock Sport Disc 29 int
Комплектация - сток:
РАМА: Specialized A1 Premium Aluminum 29er, fully butted, 6061 alloy, ORE downtube, externally relieved headtube,
forged dropouts and reinforced disc mount, alloy replaceable der. hanger
ВИЛКА: SR Suntour SF13-XCT-MLO 29", coil/MCU spring, 1-1/8" steel steerer, mechanical lock out w/ preload adj., 28mm stanchions, post mount disc, 80mm travel
РУЛЕВАЯ: 1-1/8" threadless, loose ball
ВЫНОС: Alloy, 4 bolt clamp, 10º rise, 25.4mm
РУЛЬ: Specialized flat bar, alloy, 640mm & 660mm wide, 8º backsweep, 4º upsweep, 25.4mm
ГРИПСЫ: Specialized Body Geometry XCT, Kraton w/ gel, 132mm
ПЕРЕДНИЙ ТОРМОЗ: Tektro HDC 300, hydraulic disc, dual piston, Lightwave style rotor, 160mm
ЗАДНИЙ ТОРМОЗ: Tektro HDC 300, hydraulic disc, dual piston, Lightwave style rotor, 160mm
ТОРМОЗНЫЕ РУЧКИ: Tektro, hydraulic lever
ПЕРЕДНИЙ ПЕРЕКЛЮЧАТЕЛЬ: Shimano Altus, 8-speed, 34.9mm clamp, low mount, top-swing, dual-pull
ЗАДНИЙ ПЕРЕКЛЮЧАТЕЛЬ: Shimano Acera, 9-speed, SGS Cage
МАНЕТКИ: Shimano Altus, 8-speed Rapidfire plus, SL type w/ optical display
КАССЕТА: Sunrace, 8-speed cassette, 11-34
ЦЕПЬ: KMC X-8, 8-speed w/ reusable Missing Link
СИСТЕМА: SR Suntour XCT, 8-speed, square taper spindle
ЗВЁЗДЫ: 42/32/22, steel
КАРЕТКА: Square taper, cartridge bearing, 68mm shell
ПЕДАЛИ: Composite platform, w/ reflectors, 9/16"
ОБОДА: HR Disc 29", alloy double-wall, disc, pin joint, 25mm, 36h
ПЕРЕДНЯЯ ВТУЛКА: Alloy disc hub, double sealed loose bearing, steel axle, QR, 32h
ЗАДНЯЯ ВТУЛКА: Alloy disc hub, double sealed loose bearing, steel axle, steel cassette body, QR, 32h
СПИЦЫ: Stainless, 2.0mm (14g)
ПЕРЕДНЯЯ ПОКРЫШКА: Specialized Fast Trak Sport, 29"x2.0", wire bead, 40TPI
ЗАДНЯЯ ПОКРЫШКА: Specialized Fast Trak Sport, 29"x2.0", wire bead, 40TPI
КАМЕРЫ: Schrader valve
СЕДЛО: Specialized Body Geometry Hardrock, steel rails, 143mm width
ПОДСЕДЕЛЬНЫЙ ШТЫРЬ: Alloy two bolt, 12.5mm offset, micro adjust, 30.9mm, 350mm or 400mm
ЗАЖИМ ПОДСЕДЕЛЬНОГО ШТЫРЯ: 34.9mm, alloy QR, nylon washer
Рама - L/19
Состояние отличное. Пробег - 760 км.
На велосипед есть все документы!
Цепь менялась после 500 км.
В комплекте:
- велосипед;
- насос;
- велокомпьютер (беспроводной)
Цена - 10000 грн.
тел. 093 507 36 32
Велосипед находится в Киеве
Востаннє редагувалось 6.1.17 17:29 користувачем dvladb, всього редагувалось 2 разів.
dvladb
Re: Specialized Hardrock Sport Disc 29 int 8000 грн.
Повідомлення dvladb » 6.1.17 17:28
В наличии
Останній раз піднімалось dvladb на 6.1.17 17:28.
