Двухподвес Specialized Stumpjumper
Iegor
З нами з:30.7.10 17:03
Повідомлення Iegor » 12.7.16 21:33
Ростовка М
Состояние идеальное, ездил очень мало (простоял в квартире)
Документы не могу найти, но вел чистый, вот номер рамы: wsbc601 0246126 bt2563
Комплектация под спойлером (заменил обода (MTX33), вынос, подседел, педали, сиденье и руль):
FRAME
M5 hydroformed tubing, tapered HT, PF30 BB, ISCG ’05, Command Post routing, 142mm dropouts, sealed cartridge bearing pivots, replaceable derailleur hanger, 140mm travel
REAR SHOCK
Custom Fox Triad II with AUTOSAG, custom on-the-fly 3-position compression switch 1) Lock out 2) Open 3) ProPedal, rebound adj., 197x51mm
FORK
Fox Evolution F140 RL, air spring, tapered steerer, LO and reb adj., standard drop-outs, 140mm
HEADSET
1-1/8 and 1-1/2" Threadless, Campy style upper with 1-1/2" lower, cartridge bearings
STEM
Specialized XC, 3D forged alloy, 4-bolt, 31.8mm clamp, adjustable rise, S: 60mm, M: 75, L:90, XL:105mm
HANDLEBARS
Specialized All-Mountain low-rise, 6061 butted alloy, 720mm wide, 8º backsweep, 6º upsweep, 31.8mm
GRIPS
Specialized lock-on, S/M: Grappler, Others: Grappler XL
FRONT BRAKE
Custom Avid Elixir 7 SL, hydraulic disc, alloy backed semi-metallic pad, HS-1 rotor S/M:180mm, Others: 200mm
REAR BRAKE
Custom Avid Elixir 7 SL, hydraulic disc, alloy backed semi-metallic pad, HS-1 rotor S/M:160mm, Others: 180mm
BRAKE LEVERS
Custom Avid Elixir 7 SL hydraulic, tool-less reach adj.
FRONT DERAILLEUR
SRAM X7, 10-speed, S3 direct mount for DMD, bottom-pull
REAR DERAILLEUR
SRAM X9, 10-speed, mid cage
SHIFT LEVERS
SRAM X7, 10-speed, aluminum trigger
CASSETTE
SRAM PG-1030, 10-speed, 11-36t
CHAIN
KMC X-10, 10-speed, w/ reusable Missing Link, nickel plates
CRANKSET
Custom SRAM S-1250, 7050 alloy arms, 10-speed XC Trail double, PF30 spindle, S: 170mm, Others: 175mm
CHAINRINGS
38/24, w/ alloy guard
BOTTOM BRACKET
SRAM PF30, OS press-in bearing, sealed cartridge
PEDALS
Resin Test Ride Pedals with toe clips, CEN std.
RIMS
Roval 26, alloy disc, 26mm wide, 32h
FRONT HUB
Specialized Hi Lo disc, laser-etched logo, OS 24 end caps, sealed cartridge bearing, RWS, 32h
REAR HUB
Specialized Hi Lo 142+ disc, laser-etched logo, double-sealed cartridge bearing, 12mm thru-axle, 32h
SPOKES
DT Swiss Industry stainless 2.0 (14g)
FRONT TIRE
Specialized Purgatory Control, 120 TPI, 2Bliss ready, aramid bead, dual-compound, 26x2.2"
REAR TIRE
Specialized Ground Control, 60 TPI, 2Bliss ready aramid bead, 26x2.1"
INNER TUBES
Ultralight presta valve
SADDLE
Body Geometry Henge Comp, hollow Cr-Mo rails, 143mm width
SEATPOST
2014 butted alloy, single bolt setback, 30.9mm, S/M: 350mm, Others: 400mm
SEAT BINDER
34.9mm clamp ID, 7050 hard anodized alloy collar w/ QR, black
NOTES
Protective clear coat, derailleur hanger, reflectors, owners manual
Цена – 1399 $
ЗображенняЗображенняЗображенняЗображенняЗображення
Востаннє редагувалось 3.8.16 19:00 користувачем Iegor, всього редагувалось 1 раз.
GRiNVi4
З нами з:20.6.10 02:15
Re: Двухподвес Specialized Stumpjumper
Повідомлення GRiNVi4 » 26.7.16 20:38
барахол будет?
Iegor
Повідомлення Iegor » 30.7.16 21:46
Продажа только целиком
silverdron
З нами з:29.7.16 16:15
Повідомлення silverdron » 1.8.16 12:37
Ростовка М
А можно точнее какой размер???
Размер рамы, дюймы | Ваш рост, см. | Размер рамы, cm. | Размер рамы, условн.ед. | Обозначение
17" | 156 - 170 | 43,2 | M (Meduim) | Средний
18" | 167 - 178 | 45,7 | M (Meduim) | Средний
или сообщите Ваш рост?
Iegor
Повідомлення Iegor » 1.8.16 12:41
На раме написано только М, в дюймах нет обозначений. Приезжайте и прокатимся. Или звоните 0939076766
silverdron
Повідомлення silverdron » 1.8.16 12:43
А рост у Вас какой?
Iegor
Повідомлення Iegor » 1.8.16 12:44
183 см, но на меня ориентироваться не стоит, у меня посадка нестандартная
