Двухподвес Specialized Pitch PRO Размер "М"
Wellz
З нами з:30.3.12 18:04
Повідомлення Wellz » 21.2.16 13:23
Покупался в экстрим стайле зимой 11/12, накатал за все время менее 1000 км
Регулярное ТО, квартирное хранение
Весь обвес родной, докупались только педали.
Рама не гнутая, без трещин.
Состояние велосипеда - идеальное.
Цена: 1100$
Смело звоните 066 621 22 11 Сергей
Обвес подробно:
Frame: Pitch frame, M4 tubing, double ORE downtube, DMD front derailleur mount, sealed cartridge bearing pivots, replaceable hanger, bolt on cable guides, 150mm travel
Rear Shock: Fox RP2, 2-position switch 1) ProPedal 2) full open, rebound adjust, 7.875x2.25 inch
Fork: Rockshox Pike 351 for Specialized, 140mm travel, Solo air, Motion Control damper, disc only, alloy steerer, rebound adjust, Maxle light included
Front Derailleur: Shimano M660 SLX, DMD, top swing, dual pull
Rear Derailleur: SRAM X-9, mid cage
Shifters: SRAM X-5, 9-speed trigger
Chainset: Truvativ GXP2 2.2, 2 piece crankset, AA rings, outboard bearing BB 175mm
Chainrings: 36/24 tooth chainrings
Bottom Bracket: Truvativ outboard bearing, included with crank
Cassette: Shimano HG-50, 9-speed, 11-34 tooth range
Chain: KMC X9 with reusable Missing Link
Pedals: NS bikes (material Titan)
Front Brake: Custom Avid Elixir 4, full hydraulic, alloy backed organic pads, G2 Clean Sweep rotor, 203mm
Rear Brake: Custom Avid Elixir 4, full hydraulic, alloy backed organic pads, G2 Clean Sweep rotor, 185mm
Brake Levers: Avid Elixir 4 Hydraulic
Handlebars: Alloy mid rise, butted, 31.8mm, 680mm wide, 6 degree up, 9 degree back sweep
Stem: 3D forged alloy, 8 degree rise, 31.8mm 4 bolt clamp,
Headset: 1 1/8 inch threadless
Grips: Specialized Thick lock on grip
Rims: Pitch Disc specific, 26mm, pin joint, eyelets, 32hole
Front Hub: Hi-Lo disc, 20mm thru-axle, 32 hole
Rear Hub: Disc, double sealed cartridge bearing, high/low flange with OS contact side, 32hole, quick release
Spokes: 1.8mm (15g) stainless
Front Tyre: Specialized Eskar Control, 26x2.3 inch, 60 TPI, tubeless ready, aramid bead
Rear Tyre: Specialized Eskar Control, 26x2.3 inch, 60 TPI, tubeless ready, aramid bead
Tubes: Ultralight Presta valve
Saddle: Specialized Enduro BG, 7mm hollow Cr-Mo rails
Seatpost: 2 bolt micro adjust setback head, 6061 alloy, 30.9mm
Seat Binder: Alloy collar with quick release, 34.9mm clamp ID
Accessories: Protective clear coat, derailleur hanger, reflectors, owners manual
Weight: Approx. 21.38lbs (9.7kg) for the Small Size.
Велосипед находится в Ивано-Франковске
294300308_1_1000x700_gornyy-velosiped-dvuhpodves-specialized-pitch-pro-vano-frankvsk_rev002.jpg
294300308_1_1000x700_gornyy-velosiped-dvuhpodves-specialized-pitch-pro-vano-frankvsk_rev002.jpg (75.76Кіб)Переглянуто 2057 разів
Востаннє редагувалось 22.3.16 08:38 користувачем Wellz, всього редагувалось 4 разів.
Wellz
Re: Specialized Pitch PRO '10 Продам
Повідомлення Wellz » 3.3.16 10:05
Цена 1300$
Wellz
Re: Specialized Pitch PRO '10 Продам (Цену снижено!)
Повідомлення Wellz » 10.3.16 10:07
Новая цена 1200$ !
Wellz
Повідомлення Wellz » 19.3.16 13:17
Новая цена 1100$
