Велосипед Specialized Stumpjumper FSR Expert
land2
З нами з:8.2.16 11:22
Повідомлення land2 » 8.2.16 12:12
Отличное состояние, пробег около 2000 км,размер М, покупал в Экстрем Стайле в 2009г. документы есть.
На раме и вилке есть небольшие царапины.Цена нового 3700$
Возможен обмен
Хочу 1700$
0676743580 Костя
Описание:
FRAMEAll new Stumpjumper FSR M5 manipulated alloy frame w/ ORE TT/DT, sealed cartridge bearing pivots, DMD Direct Mount F. Der, replaceable derailleur hanger, disc only, 120mm travel
REAR SHOCKSpecialized AFR Shock w/ remote Trail Tune inertia valve, adj rebound and Brain Fade, 7.25x1.75"
FORKFox F120 RLC, 120mm travel, rebound/compression adjust, lock out w/ threashold adjust, alloy steerer
HEADSET1 1/8" threadless, alloy cups w/ 10mm insertion, sealed cartridge bearing
STEMSpecialized adjustable rise, 31.8mm clamp, 3D forged w/CNC finish
HANDLEBARSSpecialized XC low rise 31.8mm bar, 2014 butted alloy, 6 degree up, 8 degree backsweep, 640mm wide
TAPE/GRIPSSpecialized thin lock on grip, dual density
FRONT BRAKECustom Avid Ultimate 7, hydraulic disc, 185 and 203mm rotor
REAR BRAKECustom Avid Ultimate 7, hydraulic disc, 160 and 185mm rotor
BRAKE LEVERSCustom Avid Ultimate 7, hydraulic disc
FRONT DERAILLEURShimano M581 LX, DMD, top swing, dual pull
REAR DERAILLEURSRAM X-0, 9-speed, mid cage
SHIFT LEVERSSRAM X-9, aluminum 9-speed trigger
CASSETTE FREEWHEELShimano HG-50, 9-speed, 11-34t
CHAINSRAM PC-971 w/ Power Link
CRANKSETShimano M762 XT custom for Specialized
CHAINRINGS22S/32A/44A, 4 bolt 104/64mm
BOTTOM BRACKET Shimano M762 XT custom for Specialized
PEDALSCrank Brothers Smarty custom for Specialized
RIMSDT Swiss custom for Specialized X420, 24mm w/ eyelets, 28/32h
FRONT HUBSpecialized Hi Lo disc, 28h CNC flange and disc mount, sealed cartridge bearing, 9mm DT RWS alloy QR
REAR HUBDT Swiss custom for Specialized 370 with DT RWS QR, 32h
SPOKESDT Swiss Competition 1.8/1.6mm
FRONT TIRES-Works The Captain 26x2.0", 120 TPI, tubeless ready aramid bead, dual compound
REAR TIRES-Works The Captain 26x2.0", 120 TPI, tubeless ready aramid bead, dual compound
TUBESSpecialized Ultralite, .6mm, presta
SADDLESpecialized XC MTB, hollow Cr-Mo rails, SL foam
SEAT POST2017 butted alloy, two bolt non-setback, 30.9 x 350/400mm
SEAT BINDERAlloy collar w/ QR, 34.9mm clamp ID
NOTESProtective clear coat, derailleur hanger, reflectors, owners manual
Оформіть тему як треба, з описом. Або вона закриється. Модератор.
land2
Re: Велосипед Specialized Stumpjumper FSR Expert
Повідомлення land2 » 29.2.16 11:03
вверх
