Выбор ободов/колес для двухподвеса Specialized-FSRxc
bO4a
З нами з:11.5.09 13:16
Повідомлення bO4a » 6.11.14 02:49
Помогите сориентироваться с новыми колесами для такого вела.
Сейчас стоят:
RIMS Mavic XM117 Disc, 26", 32h, black, presta valve 559x17, 23.8mm, ~460 g
FRONT TIRE Specialized Resolution 26x2.0", 60TPI, aramid bead, dual compound
REAR TIRE Specialized Resolution 26x2.0", 60TPI, aramid bead, dual compound
Под спойлером вся спецификация.
TECHNICAL SPECIFICATIONS
FRAME FSR M4 butted frame w/ ORE downtube, sealed cartridge bearing pivots, replaceable derailleur hanger, two sets of water bottle bosses, disc only, 100mm travel
REAR SHOCK X Fusion 02RC, Specialized tuned, rebound/compression adjust w/ lock out, 7.0x1.6"
FORK Rock Shox Recon 335, 100mm, fixed coil, lock out, turnkey damper, ext rebound adj, alloy steerer RockShox Reba Team 85-115 Air U-Turn
HEADSET 1 1/8" threadless, black steel cups, loose ball bearings w/ seals
STEM Aluminum, 7 degree rise, OS 31.8, 4 bolt, black
HANDLEBARS Specialized XC low rise, butted alloy, 640mm wide, 6 degree up, 8 degree backsweep
TAPE / GRIPS Specialized MTB, dual density
FRONT BRAKE Avid Juicy 3, hydraulic disc, G2 Clean Sweep S/M: 185mm rotor, L/XL 203mm rotor
REAR BRAKE Avid Juicy 3, hydraulic disc, G2 Clean Sweep S/M: 160mm rotor, L/XL: 185mm rotor
BRAKE LEVERS Avid Juicy 3 hydraulic
FRONT DERAILLEUR Shimano FD-M530, Deore, top swing, duall pull, 34.9mm clamp Shimano XT M780 — с верхним механизмом поворота, тройной, 10 скоростей
REAR DERAILLEUR Shimano M-751 Deore XT, long cage, standard spring Shimano XT M786 Shadow+, 10 скоростей, Black
SHIFT LEVERS Shimano SL-511 Deore, 9-speed Shimano XT M780 10 ск, Black
CASSETTE / FREEWHEEL Shimano HG50, 9-speed, 11/34t Shimano XT M771, 10 скоростей, Silver, 11-36t
CHAIN Shimano HG73
CRANKSET Shimano FCM-442-8, Octalink Spline, 9-speed, replaceable rings w/ alloy outer Shimano XT M780 10 ск Black, 104mm, 175mm,
CHAINRINGS 22s/32s/44A 4mm thick outer, 4 bolt 104/64mm 42.32.24t
BOTTOM BRACKET Shimano ES-25 Octalink Spline, 68mm shell, 118mm spindle, 50mm chainline Shimano XT M770-SLX M660 Black, 68/73mm
PEDALS Shimano 505 SPD
FRONT HUB Specialized disc, loose ball bearing, high/low flange, 32h
REAR HUB Shimano M-475L disc, 32h, 8/9-speed, alloy QR
SPOKES 1.8mm stainless, black, brass nipples
TUBES Specialized 26x2.0", schraeder
SADDLE Specialized BG MTB
SEAT POST 6061 alloy, black, 30.9 x 350/400mm
SEAT BINDER Alloy collar with QR, 34.9mm clamp ID, black
Мой вес ~ 86
Катаю легкий/агреcсивный XC, город.
Хочу поменять колеса, что бы были на хороших втулках (скорее всего Nukeproof Generator назад, вперед - ещё не определился), обод пошире, надежные спицы (DT Competition/Champion, Sapim Leader), на стоковом менял задние на более прочные, т.к. 1.8 лопались пару раз.
Катаю с защитной лентой Zefal 34 mm (75 g x 2) - ни одного прокола.
Загорелся бескамерными Stan's NoTubes:
ZTR Arch EX 26 Black - $ 94.5
Max recommended rider weight 230lbs
Rim Material 6061 Alloy
Rim Depth 15.8mm
Rim Width External 24.6mm
Rim Width Internal 21.0mm
Weight 400g
ZTR Flow EX 26 Black - $ 97.5
Max recommended rider weight 250lbs
Rim Depth 17.8mm
Rim Width External 29.1mm
Rim Width Internal 25.5mm
Weight 490g
Но сейчас по хорошей цене на чейне некоторые обода Sun Ringle:
Обод сварной МТБ Sun Ringle Inferno 25 - $ 33.74
Outside Width: 25mm
Inner bead width: 20.3mm
Section Height: 19mm
Weight: 448g
Обод сварной МТБ Sun Ringle Inferno 27 - $ 50.99
Outside Width: 27mm
Inner bead width: 22.3mm
Section Height: 20mm
Weight: 482g
Обод сварной МТБ Sun Ringle Inferno 29 - $ 36.44
Outside Width: 29mm
Inner bead width: 23.4mm
Section Height: 21mm
Weight: 520g
Ещё смотрел в сторону Spunk (Tubeless Ready):
Spank Oozy EVO 26AL - $ 58.04
MGR Dynamal Alloy
Outer Width: 26 mm
Weight: 420g
ERD: 537mm
ETRTO: 559 x 21
Spank Oozy Trail 295 Bead-Bite - $ 57.59 (только синий, нет сейчас черного)
Material: MGR Dynamal Alloy
Brake Surface: Disc Specific
Outer Width: 29.5mm
Weight: 420
ERD: 528mm
ETRTO: 559 x 25
Цены актуальны до вечера 6.11.2014...
Или остановиться на:
Колесо заднее Stans Notubes ARCH EX 26" 32 спицы черный Цена: 4095 грн Акция 3315 грн
Колесо переднее Stans Notubes ARCH EX 26" 32 спицы черный Цена: 3210 грн Акция 2625 грн
Втулка: Stans 3.30 DISC QR HUB;
Спицы: черные,32 спицы (размер 2.0мм-1.7мм);
Буду рад услышать советы/мнения по целесообразности бескамерности колес в данном случае, подходящая/оптимальная их ширина.
Жалею, что не запостил раньше...
Re: Выбор ободов/колес для двухподвеса Specialized-FSRxc
Повідомлення RealIce » 6.11.14 09:37
Nukeproof Generator = Q-lite QL-YA2R и еще Superstarcomponents их продает под своей маркой.
Это не к тому что втулки плохи. Вполне себе хороший надежный Тайвань. А к тому что может есть возможность сэкономить на фирменной надписи.
Втулки Stans вроде = Chosen
Ну и если не общепризнанный DT Swiss, то почему не Hope? Ось назад советую сразу поставить сплошную 10 мм. На подвесе это заметно увеличит жесткость заднего треугольника
По поводу ободов не подскажу. Под мои 100 у меня почти трамвайные FireEye Excelerant LT. Но под Вас это явно с избытком.
Все хвалят ZTR Arch . Да и цена вроде ОК. Flow думаю будут избыточным
bO4a
Повідомлення bO4a » 10.11.14 05:18
Спасибо за совет, прочитал в тот же день.
Пока ничего не купил, т.к. ещё не определился + цены поменялись тогда + смотрю уже в сторону вилсетов в сборе, но там свои нюансы.
На втулке DT 240s цена, конечно, не маленькая.
DT 350 и Hope Pro 2 Evo - пониже цена, что выбрать из этого? На DT 350 дешевле выходит ~ 70-80 евро, но передняя ось только QR, а на Hope Pro 2 Evo можно 9 мм Thru Bolt, как и на DT 240s
В сборке нет спиц DT Champion 2.0 ...
только такие:
DT Swiss Competition 2.0/1.8
DT Swiss Competition Race 2.0/1.6
DT Swiss Revolution 2.0/1.5
DT Swiss Aerolite 2.0/0.9/2.3
Sapim Force 2.2/1.8/2.0
Sapim D-Light 2.0/1.65
Sapim CX-Ray 2.0/2.3-0.9/2.0
Ещё есть вариант с Fun Works N-Light Evo или Fun Works 4Way Pro = DT 350 по цене
Кто, что подскажет?
