specialized crosstrail pro disc
snowg
З нами з:22.4.14 18:07
Повідомлення snowg » 26.7.14 13:53
цена 12000грн
причина - нужны деньги
тел. 0967770833
Киев.
размер 19(L)
велосипед в отличном состоянии, все работает как часы! пробег 600-800км (2013 года)
вес 12кг, на рост 177-187!
Frame:Specialized M4 Premium Aluminium double-butted smooth weld, w/ mudguard and rack
braze-ons, forged dropouts, kickstand mount
Fork:SR Suntour NCXi Coil, magnesium lower, custom integrated fork crown, integrated remote lock out, 50mm travel
Front Derailleur:SRAM X9, 2-speed
Rear Derailleur:SRAM XO, 10-speed
Number of Gears:20
Shifters:SRAM X9, 2×10-speed
Chainset:SRAM S1220, GPX, 10-speed 48/32t
Chainrings:48/32, alloy outer ring
Bottom Bracket:SRAM GXP
Cassette:SRAM PG-1070, 10-speed, 11-36
Chain:sram pc1031 10speed chain(новая цепь)
Pedals:Alloy, loose ball, w/ reflectors
Front Brake:Magura MTS, hydraulic custom disc brake, 160mm rotor
Rear Brake:Magura MTS, hydraulic custom disc brake, 160mm rotor
Brake Levers:Magura MTS hydraulic brake lever
Handlebars:Specialized double-butted, alloy Flat-Top bar, 31.8mm, 10-degree back bend
Stem:Specialized Elite-Set, 3D forged alloy, 4-position adjustable, 4-bolt 31.8mm clamp
Headset:1-1/8" FSA Campy style integrated cartridge, 8mm alloy cone spacer
Grips:Specialized xc light weight grips (новые грипсы)
Rims:SR300, 700c, alloy, double-wall, CNC sidewalls, 32h
Front Hub:Disc hub, loose ball, Hi Lo flange, machined disc side, dual lock nuts w/ 19mm contact, QR
Rear Hub:Disc hub, loose ball, Hi Lo flange, machined disc mount, double-sealed, ground race, dual lock nuts w/ 19mm contact side, QR
Spokes:Stainless, 2.0mm (14g)
Front Tyre:Specialized Trigger Sport, 700×38c, 60TPI, wire bead
Rear Tyre:Specialized Trigger Sport, 700×38c, 60TPI, wire bead
Tubes:Specialized Presta valve
Saddle:phenom gel 143 (новое седло)
Seatpost:Alloy, 2-bolt head, 12.5mm offset, 27.2mm
Seat Binder:Alloy clam
snowg
Re: specialized crosstrail pro disc
Повідомлення snowg » 12.8.14 18:23
возможен торг!
snowg
Повідомлення snowg » 11.9.14 12:51
:good: up!
Kolia Kilch
З нами з:3.4.03 13:10
Повідомлення Kolia Kilch » 21.9.14 11:20
Город?
Свою Україну любіть,
Любіть її...
Во время люте,
В остатню тяжкую минуту
За неї Господа моліть.
