Стойка для велосипедов. Специальное предложение
Запчастини та велосипеди
Повідомлення Трям » 15.10.13 18:42
( идеальное решение для участников соревнований \ команд \ клубов )
PROFESSIONAL STORAGE STAND
THE PROFESSIONAL STORAGE STAND
IS A MULTI-FUNCTION STAND FOR
CYCLE EXHIBITION, BIKE SHOP,
BICYCLE CLUB, TEAM RACING AND
SIDEWALK STORAGE WHICH IS EASY
TO ASSEMBLE AND IT'S
EXTENDABLE DESIGNED TO MAKE
EXTRAL LONGER SPACE.
TB-SS10 HAVE THREE-LEG BASE
WITH FREE MOVE SPACER VERY
STABLE.
Max weigh: 120Kg.
Height: 90cm~120cm.
Width: 120cm to 240cm.
TB-SS10: include the bag for carry.
TB-SS11: is only professional storage stand
TB-SS10 -
TB-SS11 -
предложение действует до конца недели
забрать можно будет в феврале
никаких залогов и предоплат
посмотреть пока можно только на картинке :p
...если кого интересуют другие складные стенды
или очень качественное оборудование для мастерских - пишите в почту
The dial indicator wheel truing stand design for more accuracy measurment than others , include functional type of accurate measuring , flexible use in comparing others ,and take your job easily . This is brother stand of TB-PF35
Measure wheels from 16" TO 29" with or without tire ,and the
inaccurancy of dial indicator is basic on 0.01mm
Features:
1. It is used on precision instrument, whose dial measurement reads to 0.01mm and provides you more accuracy on rear and front wheels measurement and truing while using TB-PF36
2. All-purpose arm provides users to measure and true wheels in any angles and positions you need. More smoother, easier and more accurate operation for users
3. Shift all-purpose arm onto TB-PF36 uprights, allowing users to measure and true disc brake
4. Extra long uprights to accommodate wheels up to 29”, no
need to use extra upright extensions
5. TB-PF36 comes with thru axle adaptors
6. Thru axle adaptors allow the stand to be used with wheels
using 15mm and 20mm thru axle hubs
7. Can be bench mounted
8. Truing caliper included
Super B / TB-PF36 Professional Mechanic Wheel Truing Stand
phpBB [video]
phpBB [video]
Предложение относится только к практикующим веломеханикам \ велосипедным мастерским \ велопрокатам \ веломагазинам при которых есть веломастерская ( удивительно, но есть ещё магазины без мастерских! )
