specialized stumpjumper comp 29
Melkij
X X X
З нами з:19.4.11 07:57
Повідомлення Melkij » 12.9.13 19:43
РАМА M5 fully manipulated alloy, 29" geometry, tapered HT, PF30 BB, PM 140mm rear brake, 135mm dropouts, replaceable derailleur hanger
ВИЛКА RockShox Reba RL 29, Solo air spring, alloy tapered crown/steerer, w/Lockout and rebound adj., QR, 15.5": 80mm, 17.5/19/21": 90mm travel
РУЛЕВАЯ 1-1/8 and 1-1/2" threadless, Campy style upper with 1-1/2" lower, cartridge bearings
ВЫНОС Specialized XC, 3D forged alloy, 4-bolt, 31.8mm clamp, 6-degree rise, S: 75mm, M: 90mm, L: 105mm, XL: 105mm
РУЛЬ Specialized XC flat, 2014 butted alloy, 680mm wide, 8-degree backsweep, 31.8mm
ГРИПСЫ Specialized Sip Grip, half-waffle aramid-infused, S/M: Regular, Others: XL thickness
ПЕРЕДНИЙ ТОРМОЗ Custom Magura MTS, hydraulic disc, Hi Friction pad, alloy caliper, Storm SL rotor, 160mm rotor
ЗАДНИЙ ТОРМОЗ Custom Magura MTS, hydraulic disc, Hi Friction pad, alloy caliper, Storm SL rotor, 160mm rotor
ТОРМОЗНЫЕ РУЧКИ Custom Magura MTS, alloy master cylinder/lever blade, hollow lever pivot, reach adj.
ПЕРЕДНИЙ ПЕРЕКЛЮЧАТЕЛЬ SRAM X7, 10-speed, 34.9 clamp, top pull
ЗАДНИЙ ПЕРЕКЛЮЧАТЕЛЬ SRAM X9 Type 2, 10-speed, mid cage
МАНЕТКИ SRAM X7, 10-speed, w/MatchMaker clamp
КАССЕТА SRAM PG-1030, 10-speed, 11-36
ЦЕПЬ KMC X10, nickel plate, reusable Missing Link
СИСТЕМА Custom SRAM S-1250, 7050 alloy arms, 10-speed XC double, PF30 spindle, 15.5": 170mm, Others: 175mm
ЗВЁЗДЫ 38/24
КАРЕТКА SRAM PF30, OS press-in bearing, sealed cartridge
ОБОДА Roval 29, alloy disc, 26mm wide, 32h
ПЕРЕДНЯЯ ВТУЛКА Specialized Hi Lo disc, OS28 end caps, sealed cartridge bearing, QR, 32h
ЗАДНЯЯ ВТУЛКА Specialized Hi Lo disc, double-sealed cartridge bearing, QR, 32h
СПИЦЫ DT Swiss Industry, stainless, 14g
ПЕРЕДНЯЯ ПОКРЫШКА S-Works Fast Trak, 2Bliss Ready, 120 TPI, aramid bead, 29x2.0"
ЗАДНЯЯ ПОКРЫШКА Specialized Fast Trak Control, 2Bliss Ready, 60 TPI, aramid bead, 29x2.0"
КАМЕРЫ Ultralight presta
СЕДЛО Body Geometry Phenom Comp, hollow Cr-Mo rails, 143mm
ПОДСЕДЕЛЬНЫЙ ШТЫРЬ Specialized 2014 butted alloy, single bolt setback, 27.2mm, 15.5/17.5" 350mm; Others: 400mm
ЗАЖИМ ПОДСЕДЕЛЬНОГО ШТЫРЯ Specialized 7050 hard anodized alloy, 31.8mm, single bolt
spesh 0.jpg (89.46Кіб)Переглянуто 1142 разів
spesh 00.jpg (85.27Кіб)Переглянуто 1142 разів
