Specialized Stumpjumper Comp Carbon 29
vital.
З нами з:27.6.11 23:00
Повідомлення vital. » 17.8.13 12:12
ЦВЕТ
CARB/WHT/SIL
РАМА
FACT 8m carbon with 12K finish, 29" geometry, FACT IS construction, tapered HT, carbon PF30 BB, hollow carbon dropouts, replaceable alloy derailleur hanger
ВИЛКА
RockShox Reba RL 29, Solo air spring, alloy tapered crown/steerer, w/Lockout and rebound adj., QR, 15.5": 80mm, 17.5/19/21": 90mm travel
РУЛЕВАЯ
1-1/8 and 1-1/2" threadless, Campy style upper with 1-1/2" lower, cartridge bearings
ВЫНОС
Specialized XC, 3D forged alloy, 4-bolt, 31.8mm clamp, 6-degree rise, S: 75mm, M: 90mm, L: 105mm, XL: 105mm
РУЛЬ
Specialized XC flat, 2014 butted alloy, 680mm wide, 8-degree backsweep, 31.8mm
ГРИПСЫ
Specialized Sip Grip, half-waffle aramid-infused, S/M: Regular, Others: XL thickness
ПЕРЕДНИЙ ТОРМОЗ
Custom Magura MTS, hydraulic disc, Hi Friction pad, alloy caliper, Storm SL rotor, 160mm rotor
ЗАДНИЙ ТОРМОЗ
ТОРМОЗНЫЕ РУЧКИ
Custom Magura MTS, alloy master cylinder/lever blade, hollow lever pivot, reach adj.
ПЕРЕДНИЙ ПЕРЕКЛЮЧАТЕЛЬ
SRAM X7, 10-speed, 34.9 clamp, top pull
ЗАДНИЙ ПЕРЕКЛЮЧАТЕЛЬ
Shimano XT Shadow Plus, 10-speed, SGS long cage
МАНЕТКИ
Shimano SLX 10-speed, trigger
КАССЕТА
SRAM PG-1030, 10-speed, 11-36
ЦЕПЬ
KMC X10, nickel plate, reusable Missing Link
СИСТЕМА
Custom SRAM S-1250, 7050 alloy arms, 10-speed XC double, PF30 spindle, 15.5": 170mm, Others: 175mm
ЗВЁЗДЫ
38/24
КАРЕТКА
SRAM PF30, OS press-in bearing, sealed cartridge
ПЕДАЛИ
Resin Test Ride Pedals with toe clips, CEN std.
ОБОДА
Roval 29, alloy disc, 26mm wide, 32h
ПЕРЕДНЯЯ ВТУЛКА
Specialized Hi Lo disc, OS28 end caps, sealed cartridge bearing, QR, 32h
ЗАДНЯЯ ВТУЛКА
Specialized Hi Lo disc, double-sealed cartridge bearing, QR, 32h
СПИЦЫ
DT Swiss Industry, stainless, 14g
ПЕРЕДНЯЯ ПОКРЫШКА
S-Works Fast Trak, 2Bliss Ready, 120 TPI, aramid bead, 29x2.0"
ЗАДНЯЯ ПОКРЫШКА
Specialized Fast Trak Control, 2Bliss Ready, 60 TPI, aramid bead, 29x2.0"
КАМЕРЫ
Ultralight presta
СЕДЛО
Body Geometry Phenom Comp, hollow Cr-Mo rails, 143mm
ПОДСЕДЕЛЬНЫЙ ШТЫРЬ
Specialized 2014 butted alloy, single bolt setback, 27.2mm, 15.5/17.5" 350mm; Others: 400mm
ЗАЖИМ ПОДСЕДЕЛЬНОГО ШТЫРЯ
Specialized 7050 hard anodized alloy, 32.6mm, single bolt
на велосипеді присутні незначні сліди від перевезення
місце знаходження - м.Луцк
Ціна - 16500грн
Розмір: 21"
рік - 2013
Номер рами: WSBC604131227H
Телефон - 099 777 07 60, 097 655 5 655
постійно пере-до-забанений
