Specialized Stumpjumper FSR Comp
gigant
З нами з:10.6.11 08:08
Skype:taranyukl
Повідомлення gigant » 7.2.13 19:36
Решил добавить в свою конюшню вот такой пепелац для трейла и гор самое оно)))), из ощущений катит лучше, чем скотт спарк 60, ну и обработка всяких там неровностей фоксом просто класс.
Сейчас вдуто в вилку 85пси /180 пси в аморт на вес 82 кг как раз нормально
Спецификация:
FRAME
FSR M5 manipulated alloy frame w/ Transform monocoque TT, sealed cartridge bearing pivots and rear shock mount, replaceable derailleur hanger, two sets of water bottle bosses, disc only, 120mm travel
REAR SHOCK
Fox Triad, custom on-the-fly 3-position switch 1) lock out 2) Open 3) ProPedal pedal assisting damping, adjustable rebound, 7.75x1.75"
FORK
Fox Float 130 RL, 130mm, rebound/compression adj, lock out, alloy steerer
HEADSET
1 1/8" Threadless, alloy cups w/ 10mm insertion, sealed cartridge bearing
STEM
Specialized adjustable rise, OS 31.8, 3D forged w/CNC finish
HANDLEBARS
Specialized XC low rise 31.8mm OS bar, 2014 butted alloy, 6 degree up, 8 degree backsweep, 620mm width
TAPE / GRIPS
Specialized MTB, dual density
FRONT BRAKE
Avid Juicy 5, hydraulic disc, G2 Clean Sweep S/M: 185mm rotor, L/XL 203mm rotor
REAR BRAKE
Avid Juicy 5, hydraulic disc, G2 Clean Sweep S/M: 160mm rotor, L/XL 185mm rotor
BRAKE LEVERS
Avid Juicy 5
FRONT DERAILLEUR
Shimano M581 LX, 34.9mm clamp, bottom swing, dual pull
REAR DERAILLEUR
SRAM X-9, 9-speed, long cage
SHIFT LEVERS
SRAM X-7, aluminum trigger 9-speed
CASSETTE / FREEWHEEL
Shimano HG50, 9-speed, 11/34t
CHAIN
SRAM PC-971 w /Power Link
CRANKSET
Truvativ Stylo, 2pc crank/BB
CHAINRINGS
22S/32A/44A 4mm thick outer, 4 bolt 104/64mm
BOTTOM BRACKET
Truvativ GXP, sealed outboard cartridge bearing
PEDALS
Wellgo MG-1
RIMS
DT custom for Specialized X430, 24mm w/eyelets, 32h
FRONT HUB
Specialized Stout disc, sealed cartridge bearing, high/low flange, 32h
REAR HUB
Shimano M-525 disc, 32h, alloy QR
SPOKES
DT Swiss 1.8mm stainless, black, alloy nipples
FRONT TIRE
Scwable nobby nic 26/2,25 EVO
REAR TIRE
TUBES
Specialized Ultralight 26x2.12", presta
SADDLE
Specialized BG Rival, hollow Cro-Mo rails
SEAT POST
2014 butted alloy, black, 30.9 x 350/400mm
SEAT BINDER
7050 hard annodized alloy collar w/ QR, 34.9mm clamp ID, black
NOTES
Protective clear coat, derailleur hanger, reflectors, owners manual
shooter
З нами з:8.5.03 20:06
Re: Specialized Stumpjumper FSR Comp
Повідомлення shooter » 8.2.13 11:37
похоже на какого то десептикона в собраном виде
Toutacoup
З нами з:24.7.10 13:16
Повідомлення Toutacoup » 8.2.13 11:48
Очередной спеш™
Адре Налин
З нами з:10.10.12 10:27
Повідомлення Адре Налин » 8.2.13 12:27
Вилисапет смотрится неплохо. Но выглядел бы более эффектно, если бы был сфотан на светлом фоне стены, а не на фоне старых неструганных досок. и.м.х.о. А так фих чо намальна разглядишь.
Kenny Pick
З нами з:2.9.07 22:36
Повідомлення Kenny Pick » 8.2.13 13:06
Ну это натурально в стоковый раздел перенести.
Описание намекает.
shooter
Повідомлення shooter » 8.2.13 13:11
ну ты реально глупый?
Мне тут недавно обьяснили что если сумочка и подфляжник кастомные значит и весь вел суперкастом =)))
Tonio
З нами з:11.6.04 13:59
Повідомлення Tonio » 8.2.13 13:19
7 лет назад, когда Nal и Troll купили себе такой вел, было круто проехаться на подвесе по лесным тропкам, ощутить работу подвески и т.д. Потом восторженные отзывы и эйфория сменились четким осознанием того, что вверх он тупо не едет даже после существенного облегчения.
Но если не гоняццо, а просто катать по лесу, то думаю, ок.
"Я обычный парень, не лишен простоты.
Я такой же, как он, я такой же как ты.
Я такой как все." М.Науменко
Kenny Pick
Повідомлення Kenny Pick » 8.2.13 13:23
Ах, это все из-за фотограммы, снятой в низком ключе. Не разглядел. Впрочем, в таком случае обычно рекомендуют откалибровать монитор. Пойду займусь этим пока не поздно.
Да тут же еще и фара есть!
Ты прав, Заяц. Настоящий заморский кастом, диковинный.
Glam
типа остроумный
типа остроумный
З нами з:16.8.07 21:27
Повідомлення Glam » 8.2.13 14:19
Не, ну вы, блин, слепые, да? Еще ж фендер есть. И красный колпачок на заднем ниппеле...
gigant
Skype:taranyukl
Повідомлення gigant » 8.2.13 20:33
вот троли, ты хоть ездил на таком веле что доказываешь что он не катит, чья бы корова мычала, вел катит поверь
Glam
типа остроумный
типа остроумный
Повідомлення Glam » 8.2.13 20:58
А, так это второй раунд. Ну что ж, понеслась... :p
Kenny Pick
Повідомлення Kenny Pick » 8.2.13 22:44
Давно офтальмолога посещали?
shooter
Повідомлення shooter » 9.2.13 10:51
...троли, ты хоть ездил .... чья бы корова мычала...
Щикарна! :D
я ездил, катит отвратительно :)
gigant
Skype:taranyukl
Повідомлення gigant » 9.2.13 21:10
а ну да вам же карбоновых коней подавай , да чтоб весу было до 8 кг , ну я выбрал по другим соображениям вел, для удовольствия и в горы катать, так что у вы у каждого свой цвет и приоритеты
gigant
Skype:taranyukl
Повідомлення gigant » 10.2.13 10:29
для тех кто в танке сгодня въезжал на гору 50 градусов уклона, включаю пропедал и вперед катит на ура
Говорящий Самовар
З нами з:2.9.09 22:28
Skype:omgcox
Повідомлення Говорящий Самовар » 10.2.13 11:50
50 градусов уклона
нуну
gigant
Skype:taranyukl
Повідомлення gigant » 10.2.13 12:26
не ну спорить не буду но гора была очень грутая, мож 40-45 градусов
Gornostai
Велопузiк
З нами з:5.11.08 20:32
Повідомлення Gornostai » 10.2.13 16:11
Не, мне отсюда видно, что не больше 12ти, точно-точно.
-Вы бандеровец и националист!
shooter
Повідомлення shooter » 10.2.13 16:31
я в восхищении. Может не 50, а 150? как то более круто!
а 60кмс против ветра не ездишь случайно? а то тут был у нас один...
E-fox
З нами з:22.4.06 10:10
Повідомлення E-fox » 10.2.13 16:56
Спайдермен, палишься :lol:
gigant
Skype:taranyukl
Повідомлення gigant » 10.2.13 17:16
обсуждение закрываю, продолжайте трололо пошел за попкорном
Повідомлення MaD_CameL » 10.2.13 18:56
да. так быстро слился.
победители тур де франса с завистью смотрят на этот вел, ведь они на своих супертоповых шоссерах по идеальному покрытию на Alpe-d'Huez с куда меньшим уклоном еле заезжают, а здесь такой профит!
VooDoo
З нами з:22.3.04 20:36
Повідомлення VooDoo » 10.2.13 19:06
Зачем вот так сразу раз и заклевали... ну ошибся человек с градиентом с кем не бывает на глаз. Из практики, если не торчок и ехать более менее относительно долго, то по грунту при определенных навыках заезжали вверх до 27% (замеры спортивным гармином, модель не помню). Насчет про катит/не катит помнится на какой-то из кантрийных гонок кажись в Крыму у Фокуса не было под рукой эпика и поехал на стамджампере, а потом удивленно отписался что на нем можно и кк гоняться, в смысле не все так запущено даже в этом направлении.
Glam
типа остроумный
типа остроумный
Повідомлення Glam » 10.2.13 19:34
Да, предыдущий, с Коной, три страницы продержался... Да и предыдущий заход ТС тоже подлиннее был... Пичальбида...
gigant
Skype:taranyukl
Повідомлення gigant » 12.2.13 17:45
ага слился слился, конечно смотрит нафиг нам карбон нам сталь и люминь подавай, уклон 50 градусов заезд нормальный
