Продам верную алюминиевую зебру Specialized Myka HT Disc'11
kwiki
З нами з:7.8.11 17:18
Повідомлення kwiki » 18.6.12 21:09
Цена(обязательно): 4100 грн. Торг обоснованный
Год выпуска: 2011
Телефон для связи: 0934659717
Состояние велосипеда - отличное! Пробег около 200-300 км по паркам. Причиной продажи любимца стал подвес )
Описание
FRAME Myka A1 Premium Aluminum, fully butted, women's geometry, low standover TT, ORE DT, externally relieved HT, forged dropouts w/ replaceable alloy hanger
FORK:SR Suntour SF11-XCT-V3-DS-26, 80mm, 1pc. alloy lower, 28mm Hi-Ten stanchions, coil/mcu spring w/ preload adj.
HEADSET: 1-1/8" threadless, loose ball
STEM: Alloy A-head, 4 bolt, 20 degree rise, 25.4mm clamp
HANDLEBARS: Hi-Ten riser bar, 35mm rise, 8 degree back sweep, 4 degree up
GRIPS: Specialized Myka, dual density Kraton, 130mm
FRONT BRAKE: Tektro IO Mechanical disc brake, dual pad angle adj., 160mm rotor
REAR BRAKE: Tektro IO Mechanical disc brake, dual pad angle adj., 160mm rotor
BRAKE LEVERS: Alloy, linear pull
FRONT DERAILLEUR: Shimano FD-M310 Altus, 34.9mm clamp
REAR DERAILLEUR: SRAM X.4 8sp Midcage
SHIFT LEVERS: SRAM X.3 7sp trigger
CASSETTE: SRAM PG-730, 7-speed, 12-32t
CHAIN: KMC Z7 w/ reuseable Missing Link
CRANKSET: SR SunTour, square taper spline
CHAINRINGS: 42S x 32S x 22S replaceable
BOTTOM BRACKET: Sealed cartridge, square taper, 118mm
PEDALS: Composite body, reflectors, toe clip compatible, 9/16"
RIMS: Alex HRD 26", alloy double wall, pinned, 32h
FRONT HUB: Forged alloy, double sealed, ground race, disc, QR, 32h
REAR HUB: Forged alloy, double sealed, ground race, cassette, disc, QR, 32h
SPOKES: 2mm (14g) stainless
FRONT TIRE: Specialized Fast Trak LK Sport, 26x2.0", 60TPI, wire bead
REAR TIRE: Specialized Fast Trak LK Sport, 26x2.0", 60TPI, wire bead
INNER TUBES: Schraeder valve
SADDLE: Body Geometry Women's Riva MTB, 155mm width
SEATPOST: Alloy two bolt, 12.5mm offset, micro adjust, 30.9mm
SEAT BINDER: Alloy QR, nylon washer
Назначение: кросс-кантри. Велосипед Myka HT разработан специально для женщин. Специальная женская геометрия рамы, женские грипсы, седло, вилка с мягкими пружинами, зауженный руль и другие мелочи, которые делают этот велосипед по настоящему удобным для женщин. Myka предназначена для тех, кто любит быть первооткрывателем, искать приключения и получать от этого удовольствие — катание офф-роуд — идеальный вариант. Катание XC также идеально для тех, кто хочет добавить больше нагрузок или просто для любителей активного стиля жизни. Езда по бескрайним равнинам или по крутым лесным тропинкам — идеальный байк для этих условий сочетает сбалансированное и точное управление с легковесной базой. Каждая модель Myka HT сочетает необходимые элементы дизайна, претворяя их в идеальную комбинацию функциональности и удовольствия. Обновленная Рама Specialized Myka из A1 Aluminium, женская геометрия, заниженный стендовер, нижняя труба ORE, фрезерованная рулевая труба. Крепление только для дисковых тормозов. Вилка SR Suntour SF11-XCT-V3-DS-26, жесткость пружин в зависимости от размера велосипеда, настройка прелоуда. Удобные женские грипсы Specialized Myka. Трансмиссия SRAM X-4, манетки SRAM X-3. Механические дисковые тормоза Tektro IO - простые в настройке и эффективные в любую погоду. Комфортное седло Specialized XC Women's, по боком усилено специальной тканью, которая практически не царапается, ширина 155мм. Покрышки Specialized Fast Track LK - отлчино катят и долго изнашиваются.
kwiki
Re: Продам верную алюминиевую зебру Specialized Myka HT Disc
Повідомлення kwiki » 21.6.12 08:53
Торг уместен.
kwiki
Повідомлення kwiki » 21.6.12 18:11
При покупке до конца недели перчаточки в подарок))) Зображення
Yaros
З нами з:21.4.05 12:55
Повідомлення Yaros » 24.6.12 09:41
Размер перчаток какой? )
kwiki
Повідомлення kwiki » 25.6.12 09:56
S-ка )))
kwiki
Повідомлення kwiki » 3.7.12 17:07
up!!! :Yahoo!:
kwiki
Повідомлення kwiki » 7.7.12 16:57
Зебра нашла своего хозяина)
