Specialized Hardrock Sport Disk 2012 для высоких!
aleksgarmash
З нами з:21.3.12 21:36
Повідомлення aleksgarmash » 2.6.12 10:10
Продам Specialized Hardrock Sport Disk 2012 для высоких! (23 РАМА)
Пробег 500 км по Киеву
Состояние - идеальное, царапин нет, единственное - отсутствует задняя перекидка (но она там была самая дешевая, SRAM X4 - 200 грн) - в ней лопнула задняя пружина, поэтому продается без нее
ХАРАКТЕРИСТИКИ
RAME Specialized A1 Premium Aluminum, fully butted, disc only, 6061 alloy, double ORE down tube, externally relieved head tube, forged dropouts and reinforced disc mount, alloy replaceable derailleur hanger
FORK SR Suntour XCM (SF11-XCM-V3-26-DS-MLO), 1pc. alloy lower, 30mm Hi-Ten stanchions, mechanical LO, custom women's coil/mcu spring w/ preload adj., spring assisted seals, 80mm
HEADSET 1-1/8" threadless, loose ball w/ seals
STEM 3D forged 6061 alloy, 4 bolt clamp, 10º rise, 25.4mm
HANDLEBARS Alloy XC riser bar, 8º backsweep, 4º upsweep, 25.4mm
GRIPS Specialized Enduro, dual compound
FRONT BRAKE Avid BB5 mechanical disc brake, post mount, 160mm G2 Clean Sweep rotor
REAR BRAKE Avid BB5 mechanical disc brake, post mount, 160mm G2 Clean Sweep rotor
BRAKE LEVERS Alloy "V"-brake, two-finger, linear pull
FRONT DERAILLEUR Shimano Altus, 8-speed, 34.9mm clamp, top-swing, dual-pull
REAR DERAILLEUR SRAM X4, 8-speed, mid cage
SHIFT LEVERS SRAM X4, 8-speed, trigger
CASSETTE Shimano 8-speed, 11-34t
CHAIN KMC X-8, 8-speed, reusable Missing Link
CRANKSET SR Suntour, 8-speed, Octalink spline, replaceable rings
CHAINRINGS 42/32/22, replaceable outer
BOTTOM BRACKET Shimano, Octalink spline, cartridge bearing, 68mm
PEDALS Composite platform w/ molded pins, toe clip compatible, 9/16" w/ reflectors
RIMS Alex HR Disc 26", alloy double-wall, disc, pin joint, 24mm, 32h
FRONT HUB Disc hub, high-Lo flange, sealed loose ball, machined disc mount, QR, 32h
REAR HUB Machined disc mount & flanges, double-sealed, ground race, loose ball, dual-lock nuts w/ 19mm contact side, QR, 32h
SPOKES Stainless silver, 2.0mm (14g)
FRONT TIRE Specialized Fast Trak LK Sport, 60 TPI, wire bead, 26x2.0"
REAR TIRE Specialized Fast Trak LK Sport, 60 TPI, wire bead, 26x2.0"
INNER TUBES Schrader valve
SADDLE Specialized Body Geometry Hardrock, steel rails, front and rear bumpers, 143mm width
SEATPOST Alloy, 2 bolt head, 30.9mm, 12.5mm offset, micro adjust
SEAT BINDER 34.9mm, alloy, extruded QR lever/collar
ТАК КАК НЕ ПОЛУЧИЛОСЬ ДОБАВИТЬ ИЗОБРАЖЕНИЕ - (ОЧЕНЬ ГЛЮЧИТ САЙТ) ВЫШЛЮ ФОТО НА ПОЧТУ ВЕЛИКА
Комплектация
- велокомпьютер - Specialized
- флягодержатель Specialized
- защита на перо Specialized
ЦЕНА 5000 грн за ВЕСЬ КОМПЛЕКТ
Александр
050 205 75 49
skype - garmaw15
mail - aleksgarmash@gmail.com garmaw@yandex.ru
Востаннє редагувалось 2.6.12 10:52 користувачем aleksgarmash, всього редагувалось 1 раз.
ExtremeHawk
З нами з:18.10.05 14:42
Re: Specialized Hardrock Sport Disk 2012 для высоких!
Повідомлення ExtremeHawk » 2.6.12 10:40
Цена велосипеда?
Бла, бла, бла - здесь могла быть ваша реклама :)
aleksgarmash
Повідомлення aleksgarmash » 2.6.12 10:46
Цена велосипеда?
5000 ГРН - ЗА ВЕСЬ НЕСКРОМНЫЙ КОМПЛЕКТ
