Specialized Demo 8 I, 2012 года.
Misha S
вiртуал
З нами з:16.10.07 18:27
Повідомлення Misha S » 31.5.12 12:38
Продам Specialized Demo 8 I, 2012 года.
Цвет черный,размер Л.
велу полтора месяца.От стока отличается тормозами,поставил Avid Elixir 9
цена 3600$(торг)
по вопросам 351056342ася, личка не работает.
FRAME M5 manipulated alloy, compact race design, 1-1/2" forged HT, ISCG 05 mount, cartridge bearing rear shock mount, rear derailleur protector, 200mm travel
REAR SHOCK Custom Fox Van RC, coil over w/piggy back, compression and rebound adj., 9.5x3", XS: 300, S:350, M:400, L:450
FORK RockShox Boxxer RC, alloy steerer, external compression and rebound adj., 20mm Maxle DH thru-axle, 200mm travel
HEADSET 1-1/2" integrated for 1-1/8" steerer, cartridge bearings
STEM Specialized Direct-Mount stem, 40mm length, 31.8mm, 4-bolt, forged
HANDLEBARS Specialized Demo low-rise bar, 7050 alloy, 750mm wide, 8º backsweep, 6º upsweep, 31.8mm
GRIPS Specialized lock-on, S/M: Grappler, Others: Grappler XL
FRONT BRAKE Custom Avid Elixir 7, hydraulic disc, tool-less reach adj., metallic pad, HS-1 rotor, 200mm rotor
REAR BRAKE Custom Avid Elixir 7, hydraulic disc, tool-less reach adj., metallic pad, HS-1 rotor, 180mm rotor
BRAKE LEVERS Custom Avid Elixir 7 hydraulic, tool-less reach adj., w/MatchMaker clamp
REAR DERAILLEUR SRAM X9, 10-speed, short cage
SHIFT LEVERS SRAM X7, 10-speed, aluminum trigger, w/MatchMaker clamp
CASSETTE Shimano Tiagra, 10-speed, 11-25t
CHAIN KMC X-10, 10-speed, w/ reusable Missing Link, nickel plates
CRANKSET Custom SRAM Descendant PF30, 7050 alloy arms, with Gamut P-30 chain guide
BOTTOM BRACKET SRAM PF30 DH, 83mm shell
PEDALS Specialized Benies, low profile with removable pins
RIMS Roval DH 26, 30mm wide w/eyelets, 32h
FRONT HUB Specialized Hi Lo disc, laser-etched logo, sealed cartridge bearing, 20mm thru-axle, 32h
REAR HUB Specialized Hi Lo disc, 150mm, hollow 12mm Cr-Mo axle w/ RD guard, 32h
SPOKES DT Swiss Industry 2.0, (14g) stainless
FRONT TIRE Specialized Butcher DH, wire bead, soft dual-compound, 26x2.3"
REAR TIRE Specialized Butcher DH, wire bead, soft dual compound, 26x2.3"
INNER TUBES Presta valve 26x2.4/2.75, 2.25mm thick
SADDLE Specialized DH, 8mm hollow Cr-Mo rails
SEATPOST 6061 alloy, two bolt micro adjust, no offset, 30.9mm, 300mm
SEAT BINDER 34.9mm clamp ID, 7050 hard anodized alloy collar, single bolt
