Specialized 2007 Hardrock Comp Disc
Demiurg
З нами з:16.10.06 11:57
Повідомлення Demiurg » 21.4.12 14:52
Размер L, на рост ~180-190.
Комплектация
FRAME A1 Premium Aluminum, disc only, double butted TT, ORE DT, externally relieved head tube, reinforced disc mount, forged dropouts w/ replaceable 98954020 hanger
REAR SHOCK N/A
FORK RST Gilla Plus RA Disc, 100mm, Cro-Mo steerer, 30mm stanchions, coil spring, rebound and preload adjust
HEADSET 1 1/8" threadless
STEM Specialized 3D forged alloy, two bolt, 25.4mm, 10 degree rise
HANDLEBARS Alloy 25.4mm, 38mm rise, 620mm wide, 8 degree back, 6 degree up sweep, 3.2mm thick
TAPE / GRIPS Specialized Enduro, dual density Kraton
FRONT BRAKE Avid BB5, mechanical disc, 6" G2 Clean Sweep rotor
REAR BRAKE Avid BB5, mechanical disc, 6" G2 Clean Sweep rotor
BRAKE LEVERS Avid FR-5, alloy "V"
FRONT DERAILLEUR Shimano Acera M-330
REAR DERAILLEUR Shimano Alivio M-410
SHIFT LEVERS Shimano Alivio M-410 SL Rapid Fire
CASSETTE / FREEWHEEL Shimano MFHG-40, 8-speed, 11-32t
CHAIN Shimano HG-50, 1/2" x 3/32"
CRANKSET Shimano FCM-341-8, Octalink Spline, replaceable rings
CHAINRINGS 42S/32S/22S
BOTTOM BRACKET Shimano ES-25, Octalink Spline, cartridge bearing, 68 x 126mm for 50mm chainline
PEDALS Specialized alloy platform, 9/16"
RIMS Specialized/Alex HRD 26, double wall disc w/ eyelets
FRONT HUB Specialized Hi Lo disc, 36h, CNC flange and disc mount, QR
REAR HUB Shimano M-475 Disc, cassette, 36h
SPOKES 2.0mm (14g) stainless
FRONT TIRE Specialized Resolution, 26x2.1", 60TPI, wire bead
REAR TIRE Specialized Resolution, 26x2.1", 60TPI, wire bead
TUBES Specialized schraeder valve
SADDLE Specialized Body Geometry, ATB
SEAT POST Alloy micro adjust, 30.9mm
SEAT BINDER Alloy collar w/ QR
В подарок покупателю:
1. Педали Shimano PD-M520L MTB Sport Pedals with Cleats
2. Покрышки Schwalbe Marathon Racer 1.5 x 26"
3. Велокомпьютер Cat Eye Mity 8
4. Задний проблесковый маячок Kellys
5. Крылья передние-задние Author.
5. Мелочевка россыпью - камеры, ремнабор, бортовки и т.п.
Продаю по причине переезда, да и просто хочется проапгрейдиться. Вел в хорошем состоянии, пробег 2000км, асфальт, проселки типа Пущи-Водицы. До 27 апреля звонить, потом писать в личку.
Цена 3200. Тел. +380 50 312 7990
Demiurg
Re: Specialized 2007 Hardrock Comp Disc
Повідомлення Demiurg » 21.4.12 17:23
Продан.
