ПРОДАЮ Specialized BigHit III 2008 в ОТЛИЧНОМ СОСТОЯНИИ
XT-RAZ
З нами з:5.4.12 10:24
Повідомлення XT-RAZ » 5.4.12 13:15
Продаю свой бигхит. В отличном состоянии, в соревнованиях не участвовал, катал изредка по городу и кросс-кантри (занимаюсь мото и квадрокроссом - стало лень педали крутить). Всё, кроме грипсов (Primo), ещё стоковое.
Ростовка S.
Полная комплектация:
http://www.specialized.com/us/en/bc/SBC ... d=08BigHit
FRAME BigHit FSR, A1 Premium Aluminum ORE TT/DT, full cartridge bearing pivots, ISCG mount, asymetrical rear triangle, 26" F/R wheel, 8.2" travel, adj. geometry
REAR SHOCK Fox DHX 4.0, 8.75x2.75", adjustable rebound, ProPedal, IFP pressure, S:400, M:450, L:500
FORK Marzocchi 888 RV, 200mm travel, alloy steerer, external rebound adjust, double clamp, 20mm thru axle
HEADSET 5 1/8" threadless, 7050 alloy cups w/ oversize lower cup and bearing
STEM Truvativ Hussefelt forged/CNC, 40mm, 31.8 clamp
HANDLEBARS Specialized Big Hit rise bar, 6061 alloy, 31.8mm, 6 degree up, 9 degree backsweep, 680mm wide
TAPE/GRIPS Primo
FRONT BRAKE Avid Juicy 5, hydraulic disc, 203mm rotor
REAR BRAKE Avid Juicy 5, hydraulic disc, 203mm rotor
BRAKE LEVERS Avid Juicy 5, hydraulic disc
REAR DERAILLEUR SRAM X-9, 9-speed, short cage
SHIFT LEVERS SRAM X-7, aluminum 9-speed trigger
CASSETTE FREEWHEEL Shimano HG-50, 9-speed, 11-34t
CHAIN SRAM PC-971 w/ Power Link
CRANKSET Truvativ Hussefelt, 170mm w/ SBC chain guide
CHAINRINGS 36T, 4 bolt, compact 104mm pattern
BOTTOM BRACKET Truvativ Howitzer XR outboard bearing, 51mm chainline, 73mm shell
PEDALS Specialized Lo-Pro alloy
RIMS DT Swiss/Specialized E540, 28mm w/ eyelets, 36h
FRONT HUB Specialized disc, 20mm thru axle, 36h
REAR HUB Specialized bolt-on 135mm, hollow 10mm Cr-Mo axle w/ RD guard
SPOKES 2.0mm (14g) stainless, black, brass nipples
FRONT TIRE Specialized Chunder 26x2.3", 60TPI, aramid bead, cap ply, soft dual compound
REAR TIRE Specialized Chunder 26x2.3", 60TPI, aramid bead, cap ply, soft dual compound
TUBES Specialized, 1.2mm, schraeder valve
SADDLE Specialized Enduro, 8mm Cr-Mo rails, SL foam
SEAT POST 6061 butted alloy, two bolt setback, 30.9 x 300mm
SEAT BINDER Alloy collar w/ QR, 34.9mm clamp ID
Укрупнённые фото пришлю по запросу.
Отдам за 1600 у.е., адекватным - торг уместен. Вел в Севастополе.
Тел: О97 ОО3 ООО2
XT-RAZ
Re: ПРОДАЮ Specialized BigHit III 2008 в ОТЛИЧНОМ СОСТОЯНИИ
Повідомлення XT-RAZ » 6.4.12 12:43
XT-RAZ
Повідомлення XT-RAZ » 6.4.12 17:43
Фото свежие, сделаны 06.04.2012
XT-RAZ
Повідомлення XT-RAZ » 14.4.12 09:38
Лайбик продан. Всем спасибо за внимание.
