Выбор базы
Pequignet
З нами з:4.4.12 08:35
Выбор базы
Повідомлення Pequignet » 4.4.12 10:00
Рост 170
Вес 60
Бюджет ~7000
Вариант
Alu Lite AMF 6061 RFR-Geometry, Disc only
14", 16", 18", 20", 22"
Grey 'n' Blue
Suntour XCM Lockout 100mm
FSA No.10 semi-integrated
Easton EA30 Oversized
Easton EA30 Lowriser Oversized
CUBE Performance Grip
Shimano Alivio RD-M410 Top Normal 8-speed
Shimano FD-M310, Top Swing 34,9mm, 8-speed
Shimano SL- M310 Shifter Acera Rapidfire-Plus, 8-speed
Shimano BR-M445 hydr. discbrake(160/160mm)
Shimano Acera FC-M361 42x32x22T, Shimano BB-UN26
Alex ZX 24
Shimano HB-RM66 Disc
Schwalbe Smart Sam 2.25
Impac AV14
Fasten Alu
Scape Active 8
Scape Active 8
Scape Varioclose 34.9mm
DT Industry
13,7 k
Также присмотрелся
FRAME Specialized M4 fully manipulated alloy frame, fully butted, externally relieved HT, forged dropouts w/ replaceable derailleur hanger, disc only
FORK SR Suntour SF11-XCR-DS-26-LO-SP, 1-1/8" alloy steer, mag. lower, 30mm stanchions, hyd. damping w/ lock out and custom tuned spike valve
HEADSET 1-1/8" threadless, loose ball
STEM 3D forged alloy, 7 degree rise, 31.8mm clamp
HANDLEBARS Butted alloy riserbar, 25mm rise, 8 degree back sweep, 6 degree up
GRIPS Specialized Enduro, dual compound Kraton, no flange, 131mm
FRONT BRAKE Tektro Draco Hydraulic disc brake, dual piston, 160mm rotor
REAR BRAKE Tektro Draco Hydraulic disc brake, dual piston, 160mm rotor
BRAKE LEVERS Tektro Draco hydraulic
FRONT DERAILLEUR Shimano Alivo, 34.9mm clamp, top swing, dual pull
REAR DERAILLEUR Shimano Alivio, 9sp direct mount Long cage
SHIFT LEVERS Shimano Alivo SL, rapid fire trigger
CASSETTE Shimano HG30, 9-speed, 11-34t
CHAIN KMC X9 w/ reusable Missing Link
CRANKSET Shimano FC-M430-8, Octalink spline
CHAINRINGS 44S x 32S x 22S replaceable
BOTTOM BRACKET Shimano BB-ES25, Octalink spline, cartridge bearing, 68mm x 118mm
PEDALS Alloy 1pc. body and cage, reflector kit, 9/16"
RIMS Alex RHD 26", alloy double wall, pinned w/eyelets
FRONT HUB Forged alloy, hi/low flange, double sealed, ground race, machined disc mount and flange, QR, 28h
REAR HUB Forged alloy, mid flange, double sealed, ground race, machined disc mount and flanges, cassette, QR, 32h
SPOKES 2mm (14g) stainless
FRONT TIRE Specialized The Captain Sport, 26x2.0", 60TPI, wire bead
REAR TIRE Specialized The Captain Sport, 26x2.0", 60TPI, wire bead
INNER TUBES Presta valve
SADDLE Specialized Rockhopper XC, Body Geometry, 143mm width, front and rear bumpers
SEATPOST Alloy two bolt, 12.5mm offset, micro adjust, 30.9mm
SEAT BINDER Forged alloy QR, brass washer
Что посоветуете, возможно альтернативы иных производителей или другие модели..
Катаюсь в городе и за его пределами..
Re: Выбор базы
Повідомлення MaD_CameL » 4.4.12 12:12
оба велосипеда вполне неплохи, но эти бренды достаточно дорогие.
спеш получше будет, но за 7 тысяч можно уже купить велосипед с воздушной вилкой(она настраивается под вес гонщика) более высокого уровня.
http://www.kellys.com.ua/bike.php?b=kel ... GEN+EXPERT
а аналоги такого куба стоят порядка пяти-пяти с половиной тысяч.
хотя если велосипед очень нравится, то надо брать - обвес можно потом поменять на лучший, а нравится за деньги не купить :)
Pequignet
Re: Выбор базы
Повідомлення Pequignet » 4.4.12 12:35
Интересует качественная база (рама) для дальнейшего апгрейда.. Кстати, есть ли отличичия у рам Cube Aim/Analog.. Потому что в этих ценовых катигориях Спеш Хардрок и Рокхопер, которые в принципи отличны по назначению и рамам..
Re: Выбор базы
Повідомлення MaD_CameL » 4.4.12 12:56
рокахоппер лучше хардрока. по кубам не знаю. велосипеды, рамы, которых принципиально различаются по уровню стоят совсем других денег.
а лоуэнд +/- одинаков у всех производителей
Pequignet
Re: Выбор базы
Повідомлення Pequignet » 5.4.12 19:17
Вот еще вариант:
Рама: ORBEA MTB ALU
Вилка: SUNTOUR XCR HLO REMOTE 100
Система: SHIMANO FC-M171 24x34x42
Рулевая: 1 1/8 AHEAD
Руль: ORBEA OC-I RAISED
Вынос: ORBEA OC-I
Манетки: SHIMANO M 310
Тормоза: SHIMANO 445 DISC
Задний Переключатель: SHIMANO DEORE SHADOW
Передний Переключатель: SHIMANO TX50
Цепь: KMC Z8
Колеса: ORBEA MTB 26 DISC
Кассета: SHIMANO HG31 11-32 8S
Покрышки: KENDA MTB 26x1.95
Педали: ORBEA STEEL CAGE
Седло: SELLE ROYAL MATCH
Подседельный Штырь: ORBEA OC-I
Re: Выбор базы
Повідомлення MaD_CameL » 5.4.12 20:24
хорошая вилка(как у спеша) и трансмиссия низкого уровня. передний переклюк вообще торней :(
такое.
выбирайте по цвету
Pequignet
Re: Выбор базы
Повідомлення Pequignet » 5.4.12 23:11
У всех разная ЕТТ.. А времени на "примерку" практически нет :(
А как по вашему сравнивая орб и куб? :)
Re: Выбор базы
Повідомлення MaD_CameL » 5.4.12 23:13
никак. надо подбирать тот, что удобный.
Re: Выбор базы
Повідомлення MaD_CameL » 5.4.12 23:15
но у куба обвес посбалансированнее, а то вот эти дурацкие фокусы с передним торнеем, и деором сзади вообще некомильфо
Pequignet
Re: Выбор базы
Повідомлення Pequignet » 8.4.12 17:33
Выбор сделан, жду 10 числа и получки)) Брать буду все же Orbea.. только возможно немного другую модель (попался вариант хороший^^)
Остались только сомнения по ростовке.. 16 рама - проходит ладонь и еще чуть чуть, 18 рама - два пальца.
Pequignet
Re: Выбор базы
Повідомлення Pequignet » 18.4.12 22:49
Купил Orbea..
Востаннє редагувалось 24.10.12 21:52 користувачем Pequignet, всього редагувалось 1 раз.
Re: Выбор базы
Повідомлення MaD_CameL » 18.4.12 22:52
поздравляю! главное, что вам нравится.
ну и вам повезло, что прошлогодний со скидкой оказался в нужном размере :)
теперь кататься! все-таки какая ни есть, но ВЕСНА!
