Specialized Sirrus Elite XL (61cm) HYBRID
mimino555
З нами з:15.3.12 11:51
Повідомлення mimino555 » 27.3.12 22:49
Гібрид
ростовка 61см ХL
TECHNICAL SPECIFICATIONSGEOMETRY
FRAME Specialized compact design, A1Premium Aluminum, fully double butted and heat-treated, with fender and rack braze-ons
FORK Specialized Carbon-2 Zertz, bonded high modulus carbon fiber legs, 1 1/8" Cr-Mo threadless steerer, cantilever brake posts
HEADSET Intellaset, 1 1/8� integrated threadless, alloy cap, alloy cone spacer
STEM Specialized adjustable, 3D forged alloy
HANDLEBARS Specialized Event, A1 alloy, 580mm width
TAPE / GRIPS Body Geometry, triple density gel
FRONT BRAKE Forged 6061 alloy, 85mm linear pull, multi condition pad
REAR BRAKE Forged 6061 alloy, 85mm linear pull, multi condition pad
BRAKE LEVERS Forged alloy linear pull
FRONT DERAILLEUR Shimano Deore, 31.8 clamp, bottom pull
REAR DERAILLEUR Shimano Tiagra
SHIFT LEVERS Shimano R-440-8, Rapidfire
CASSETTE Shimano HG-50, 8-speed, 12x25t
CHAIN Shimano HG-53
CRANKSET Specialized Elite, five arm, polished arms
CHAINRINGS 50x34 RPM
BOTTOM BRACKET TH Sport, square taper, 68mm shell, 113mm spindle, sealed cartridge
PEDALS Composite body, alloy cage, Cr-Mo axle
RIMS Shimano, 700c, alloy single wall, eyelets, machined sidewalls, black
FRONT HUB Specialized Forged Alloy, 28 hole, double sealed bearings, QR, black
REAR HUB Specialized Forged Alloy, 32 hole, double sealed freehub, QR, black
SPOKES Specialized 2.0mm (14g), stainless, brass nipples, L293/R293mm front, L292/R290mm rear
FRONT TIRE Specialized All Condition, 700 x 28c, Armadillo
REAR TIRE Specialized All Condition, 700 x 28c, Armadillo
TUBES Specialized presta valve
SADDLE Body Geometry Milano Comfort Max
SEAT POST Alloy suspension, 27.2 x 350mm, preload adjust
SEAT BINDER Specialized Cr-Mo, allen head binder bolt
063 355 65 0 один
097 70 66 22пять
номер рами : P4IU30220
355euro
Re: Specialized Sirrus Elite XL (61cm) HYBRID
Повідомлення Трям » 28.3.12 01:05
год выпуска ?
пробег ?
( и чисто от меня вопрос - чем вы руководствовались, поставив именно такую цену ? )
\ можно не отвечать \
