инфо. с сайта производителя:
System: Hydraulic Disc Brake System
Piston: Open system, Dual piston
Material: Cast aluminum lever and bracket
Lever Blade: 2.5 finger lever blade
Hose Length: Front: 750 mm / Rear: 1500 mm
Rotor: TR160-7: Ø160 mm ( Light wave )
Rotor Weight: 112 grams
Adapter: AQ1.0 Series
Fluid: Tektro mineral oil
Pads: A10.11
Weight: Front wheel: 311 grams
Rear wheel: 327 grams
(Excludes rotor, adapter & mounting bolts)
