Specialized Demo 8.1 2011
Misha S
вiртуал
З нами з:16.10.07 18:27
Повідомлення Misha S » 5.12.11 12:23
неспешно начинаю поиск клиента на свой лясик..
Specialized Demo 8.1 2011.сток,размер L
был куплен в мае 11года
Использовался по назначению..
Из серьезных повреждений- потертость на ноге,пару вмятинок на заднем ободе.
Имеются коцки,царапины..
трещин,вмятин нет!
цена 2800$,торu
фото позже.
Вел в Одессе
FRAME M5 manipulated alloy, compact race design, 1.5" forged HT, Magnesium link, ISCG 05 mount, cartridge bearing rear shock mount, rear derailleur protector, 8" travel
REAR SHOCK Custom Fox Van RC, coil over w/piggy back, compression and rebound adj., 9.5x3", XS: 300, S:350, M:400, L:450
FORK RockShox Boxxer RC, alloy steerer, external compression and rebound adj., 20mm Maxle DH thru-axle, 200mm travel
HEADSET 1.5" integrated for 1 1/8" steerer, cartridge bearings
STEM Specialized direct mount stem, laser-etched, 31.8mm clamp, 4-bolt, forged
HANDLEBARS Specialized Demo low-rise bar, 7050 alloy, 750mm wide, 8 degree backsweep, 6 degree up, 31.8mm
GRIPS Specialized Grappler lock-on
FRONT BRAKE Custom Avid Elixir R, hydraulic disc, reach adjust, metallic pads, 203mm rotor
REAR BRAKE Custom Avid Elixir R, hydraulic disc, reach adjust, metallic pads, 185mm rotor
BRAKE LEVERS Custom Avid Elixir R hydraulic, tool-less reach adj.
REAR DERAILLEUR SRAM X.9, 9-speed, short cage
SHIFT LEVERS SRAM X.7, 9-speed, aluminum trigger
CASSETTE SRAM PG-970, 12-26t
CHAIN SRAM PC-971, 9-speed w/Power Link
CRANKSET BlackBox SRAM Descendant, 7050 alloy arms, GXP spindle, custom 36t ring, Gamut bash guard
BOTTOM BRACKET Custom SRAM PF-30 DH, 83mm shell
PEDALS Specialized Lo-Pro alloy, removeable pins, 9/16"
RIMS Custom DT Swiss F550, 30mm wide, 32h
FRONT HUB Specialized Hi Lo disc, laser-etched logo, sealed cartridge bearing, 20mm thru-axle, 32h
REAR HUB Specialized Hi Lo disc, 150mm, hollow 12mm Cr-Mo axle w/ RD guard, 32h
SPOKES DT Swiss Champion 2.0mm (14g) stainless
FRONT TIRE Specialized Butcher DH, DH casing, wire bead, soft dual compound, 26x2.3"
REAR TIRE Specialized Butcher DH, DH casing, wire bead, soft dual compound, 26x2.3"
INNER TUBES Schraeder valve 26x2.4/2.75, 2.25mm thick
SADDLE Specialized Demo, 7mm hollow Cr-Mo rails
SEATPOST 6061 alloy, two bolt micro adjust, no offset, 30.9mm, 300mm
SEAT BINDER 34.9mm clamp ID, 7050 hard annodized alloy collar, black
Misha S
вiртуал
Re: Specialized Demo 8.1 2011
Повідомлення Misha S » 14.12.11 23:35
krupus
З нами з:14.1.10 23:00
Повідомлення krupus » 17.12.11 18:13
Причина продажи? Обычно такие новые аппараты не продают - ими пользуются по назначению и ловят кайф от этой чудо техники.
Виталий 063-72-52-772
https://www.facebook.com/krupus
Misha S
вiртуал
Повідомлення Misha S » 18.12.11 10:05
так и есть)Продаю, так как хочу взять такой же, только 8.2!!
Misha S
вiртуал
Повідомлення Misha S » 27.12.11 21:40
опопоп
