Изучу спрос на Specialized Stumpjumper FSR Comp
Мессершмитт
З нами з:5.7.11 23:18
Повідомлення Мессершмитт » 13.9.11 23:25
Frame: Stumpjumper FSR M5 manipulated alloy frame with ORE top and down tube. Sealed cartridge bearing pivots with 120mm of travel. DMD Direct Mount front Derailleur. Replaceable derailleur hanger.
Rear Shock: Fox Triad with custom, on-the-fly 3-position switch. 1: Lock out. 2: Open. 3: ProPedal pedal assisting damping. Adjustable rebound. 7.25x1.75"
Fork: Fox Float 120 RL with 120mm of travel. Rebound/compression adjust with lock out and alloy steerer.
Front Derailleur: Shimano M581 LX dual pull with DMD top swing.
Rear Derailleur: SRAM X-9 9 speed mid cage.
Shifters: SRAM X-7 aluminium 9 speed trigger.
Chainset: Shimano M542 2 piece custom for Specialized.
Chainrings: 44/32/22, 4 bolt 104/64mm.
Bottom Bracket: Shimano M542 2 piece custom for Specialized.
Cassette: Shimano HG-50 9 speed with a 11-34 tooth range.
Chain: SRAM PC-971 with power link.
Pedals: Crank Brothers Smarty custom for Specialized.
Front Brake: Custom Avid Juicy 5 SL hydraulic disc brake with 203mm rotor. (Please note: Small and Medium sizes come with a 185mm rotor)
Rear Brake: Custom Avid Juicy 5 SL hydraulic disc brake with 185mm rotor. (Please note: Small and Medium sizes come with a 160mm rotor)
Brake Levers: Custom Avid Juicy 5 SL hydraulic disc levers.
Handlebars: Specialized XC low rise 2014 butted alloy bar. 640mm wide with a 6 degree up and 8 degree backsweep. 31.8mm.
Stem: Specialized adjustable rise stem. 3D forged with CNC finish and 31.8mm clamp.
Headset: 1 1/8" threadless alloy cups with 10mm insertion and sealed cartridge bearing.
Grips: Specialized thin lock on dual density grips.
Rims: DT Swiss custom for Specialized X420. 24mm with eyelets.
Front Hub: Specialized Hi Lo disc 28 hole hub with CNC flanges and disc mount. Sealed cartridge bearing and a 9mm DT RWS alloy quick release.
Rear Hub: Specialized custom M525SL hub for specialized with alloy quick release.
Spokes: DT Swiss 1.8mm stainless with alloy nipples.
Front Tyre: S-Works The Captain dual compound 26x2.0". 120TPI tubeless ready aramid bead.
Rear Tyre: S-Works The Captain dual compound 26x2.0". 120TPI tubeless ready aramid bead.
Tubes: Specialized Ultralite 0.6mm presta.
Saddle: Specialized XC MTB with SL foam and hollow Cr-Mo rails.
Seatpost: 2015 butted alloy two-bolt, non-setback. 30.9mm.
Seat Binder: Alloy collar with quick release. 34.9mm clamp ID.
Колёса другие.
Цена 1500 у.е. Тел.0677655665
http://i058.radikal.ru/1109/ff/af2d980b378e.jpg
http://s40.radikal.ru/i087/1109/6b/5bb4dd0399aa.jpg
http://s57.radikal.ru/i158/1109/2d/67e4bde12e6d.jpg
http://i036.radikal.ru/1109/68/f8a789483260.jpg
http://s008.radikal.ru/i303/1109/e4/d7a18a3dde06.jpg
http://s57.radikal.ru/i155/1109/9e/e46f2cca7f12.jpg
http://s49.radikal.ru/i123/1109/6d/e2b4d4bae68f.jpg
http://s43.radikal.ru/i101/1109/c0/290a0b6b9900.jpg
http://s005.radikal.ru/i209/1109/2e/347540cc0b5a.jpg
http://i013.radikal.ru/1109/72/7aafd000334a.jpg
http://i017.radikal.ru/1109/f1/ea10d49e792b.jpg
http://s52.radikal.ru/i138/1109/6c/b7f6b360b2e3.jpg
http://s005.radikal.ru/i210/1109/2d/491cb1c0e921.jpg
http://i046.radikal.ru/1109/3b/891ebff66234.jpg
http://s008.radikal.ru/i303/1109/19/0463a27e6a6d.jpg
http://i080.radikal.ru/1109/5d/62e1c758876d.jpg
http://s001.radikal.ru/i194/1109/4a/bb9dc8e9c180.jpg
http://s005.radikal.ru/i211/1109/72/65006818c769.jpg
http://s47.radikal.ru/i115/1109/26/b0dfc37f81ff.jpg
http://s013.radikal.ru/i325/1109/be/71a38b8481ca.jpg
Moder # 7モ7 #
З нами з:24.7.07 17:14
Re: Изучу спрос на Specialized Stumpjumper FSR Comp
Повідомлення Moder # 7モ7 # » 14.9.11 10:32
Как на счет описания на рус./укр. языке?
Как на счет указать пробег? Следы эксплуатации?
5trovi4
З нами з:10.8.10 13:53
Skype:dgurianov
Повідомлення 5trovi4 » 14.9.11 11:23
Еще нету размера рамы. И это пичалит шансы продажи.
