Specialized Hardrock Sport Disc 2011 (Нужна помощь)
ProximO™
З нами з:29.8.11 20:03
Повідомлення ProximO™ » 29.8.11 20:39
Характеристики Горный велосипед Specialized Hardrock SPORT DISC 2011
Рама Specialized A1 Premium Aluminum, fully butted, formed TT, Double ORE DT, externally relieved HT, reinforced disc mount, forged dropouts w/ replaceable hanger, disc only/
Вилка SR Suntour SF11-XCM-V3-26-DS-MLO, 80mm, 1pc. alloy lower, 30mm Hi-Ten stanchions, mechanical LO, coil/mcu spring w/ preload adj., spring assisted seals preload
Рулевая 1-1/8" threadless, loose ball
Передняя втулка Forged alloy, hi/low flange, double sealed, ground race, machined disc mount and flange, QR, 32h
Передние спицы 2mm (14g) stainless
Передний обод Alex RHD 26", alloy double wall, pinned w/eyelets
Задняя втулка Forged alloy, mid flange, double sealed, ground race, machined disc mount and flanges, cassette, QR, 32h
Задние спицы 2mm (14g) stainless
Задний обод Alex RHD 26", alloy double wall, pinned w/eyelets
Резина на переднем колесе Specialized Fast Trak LK Sport, 26x2.0", 60TPI, wire bead
Резина на заднем колесе Specialized Fast Trak LK Sport, 26x2.0", 60TPI, wire bead
Камеры Schraeder valve
Передний переключатель Shimano Altus, 34.9mm clamp
Задний переключатель SRAM X.4 8sp Midcage
Манетки SRAM X.4 8sp trigger
Система SR SunTour, Octalink spline 42S x 32S x 22S replaceable
Каретка Shimano BB-ES25, Octalink spline, cartridge bearing, 68mm x 118mm
Кассета SRAM PG-820, 8-speed, 11-32t
Цепь KMC X8 w/ reuseable Missing Link
Тормоза Avid BB5, mechanical disc, 160mm G2 Clean Sweep rotor
Тормозные ручки Alloy, linear pull
Руль Alloy riserbar, 25mm rise, 8 degree back sweep, 6 degree up
Грипсы Specialized Enduro, dual compound Kraton, no flange, 131mm
Вынос 3D forged alloy, 4 bolt, 10 degree rise, 25.4mm clamp
Глагол Alloy two bolt, 12.5mm offset, micro adjust, 30.9mm
Седло Specialized XC, Body Geometry, 143mm width, front and rear bumpers
Педали Composite platform, toe clip compatible, 9/16" w/ reflectors
Вот выбрал велосипед
но есть пару вопросов
1. Выдержит ли данная рама моё тело Рост 185кг. Вес 103-107 кг. ?
2. Могу ли Я на нем полноценно прыгать на скорости с бровок не треснет ли рама под мной?
Re: Specialized Hardrock Sport Disc 2011 (Нужна помощь)
Повідомлення Трям » 29.8.11 23:09
Выдержит
Он ведь на гарантии *oops*
ProximO™
Повідомлення ProximO™ » 29.8.11 23:33
на форуме очень сильно критикуют вилку "жесткая"
скажите чем оно может мне обернутся во время езды по городу/за городом?
Повідомлення MaD_CameL » 29.8.11 23:53
тем, что она не будет как надо обрабатывать неровности. под вашей массой она может вообще сплющиться на весь ход и быть почти жесткой.
но это произойдет с любой вилкой этой ценовой категории
ProximO™
Повідомлення ProximO™ » 30.8.11 16:11
видел в живую , проехался
не понравился вынос руля :(
подскажите сколько примерно стоит нормальный (красивый) вынос?
Повідомлення MaD_CameL » 30.8.11 16:14
красота в глазах смотрящего. дизайнеры спеша посчитали этот вынос красивым :)
я считаю, что рамы у хардрока ужасно уродливы, а вам похоже нравится.
а цена выноса зависит от многих факторов. и стоят они от сотни грн до нескольких сот баков
